Derivation of Lienard-Wiechart
  • Thread starter Thread starter snoopies622
    Derivation
The discussion focuses on the derivation of the Lienard-Wiechert potential formulas from Maxwell's equations and the nature of the four-vector potential. Participants clarify that the four-vector potential, consisting of the electric potential and magnetic vector potential, is structured to ensure charge conservation across Lorentz transformations. The continuity equation, expressed as ∂μAμ=0, is emphasized as crucial for maintaining this conservation in any Lorentz system. Additionally, the conversation touches on the validity of the curl operation in four-dimensional vector fields, linking it to the Faraday tensor. Overall, the discussion highlights the mathematical foundations that connect electromagnetism and relativistic physics.
snoopies622
Can anyone point me to a derivation of the Lienard-Wiechart potential formulas? I assume that they can be derived from Maxwell's equations alone.
Thanks.
That is very helpful, thank you.
A follow-up question, if I may:
What makes
<br /> <br /> ( \frac {\phi }{c} , A^x , A^y , A^z )<br /> <br />
a four-vector? That is, why is applying a Lorentz transformation to it vaild? Is the electric potential somehow the time-component of the magnetic potential? Is
<br /> <br /> \vec B = \nabla \times \vec A<br /> <br />
still valid if A is four dimensional? Is the curl of a four-dimensional vector field even defined?
snoopies622 said:
Is
The analog of that equation is Fαβ = ∂αAβ - ∂βAα. The thing on the right is the four dimensional curl. The thing on the left is the Farady tensor.
What makes
a four-vector? That is, why is applying a Lorentz transformation to it valid? Is the electric potential somehow the time-component of the magnetic potential?
(\phi,{\vec A}) is chosen to be a 4-vector in a LT so that the continuity equation
\partial_\mu A^\mu=0 will hold in any LT so charge conservation will hold in any Loentz system.
They are no longer called the electric and magnetic potential, but just the 4-vector potential.
OK, good. Thanks.
clem said:
(\phi,{\vec A}) is chosen to be a 4-vector in a LT so that the continuity equation \partial_\mu A^\mu=0 will hold in any LT so charge conservation will hold in any Loentz system.
I'm sorry - could you re-word this? I'm not sure I get your meaning.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
