Derivation of the Boltzmann Distribution
The discussion focuses on the application of the Lagrange Multiplier method in deriving the Boltzmann distribution, particularly the differentiation process. A key point is the distinction between partial differentiation and total differentiation; the former treats the total number of particles, N, as a constant, while the latter does not. The confusion arises when substituting N with its expression in terms of N_i before differentiation, which leads to additional terms that alter the outcome. The correct approach is to use partial differentiation since N is fixed in this context, allowing for the proper treatment of the N_i variables. Understanding when to apply partial versus total differentiation is crucial for obtaining the correct results in statistical mechanics derivations.
Peter Forbes
I have a question about the Lagrange Multiplier method used to derive the Boltzmann distribution. I'm following the first http://en.wikipedia.org/wiki/Maxwell%E2%80%93Boltzmann_statistics" .
I can get to this equation fine:
And I understand how they get the next line,
<br /> \frac{df}{dN_i}=\ln{g_i}-\ln{N_i}-(\alpha+\beta \epsilon_i)<br />
by considering N a constant when they do the partial differentiation.
However, since N=\sum_{i=1}^n N_i, can't I substitute that expression everywhere I have a N in the first equation? Then the differentiation gives me
<br /> \frac{df}{dN_i}=\ln{(\sum_{i=1}^n N_i)}+(\alpha-1)(\sum_{i=1}^n N_i)+\ln{g_i}-\ln{N_i}-(\alpha+\beta \epsilon_i)<br />
Which clearly has a different solution. Substituting for N before doing the partial derivative changes things...but why? I don't understand how one way should be any "more correct" than the other.
Thanks in advance.
Actually you misquoted the Wikipedia page, it doesn't say
but it says
<br /> \frac{\partial f}{\partial N_i}=\ln{g_i}-\ln{N_i}-(\alpha+\beta \epsilon_i).<br />
The difference is the d on the left-hand side. If you do a partial derivation (with the curly d) with respect to N_i then you get the result that is given, because we can treat N as a constant. If you do a complete derivation (with the straight d) then indeed you get some extra terms:
\frac{df}{dN_i} = \frac{\partial f}{\partial N_i} + \frac{\partial f}{\partial N} \frac{\partial N}{\partial N_i}
assuming that none of the other quantities (g_i, \epsilon_i, \ldots) depends on Ni implicitly.
In this case, the partial derivative is the correct one because you are allowing the Ni's to vary, but you have a constraint on N (namely that the total number of particles is fixed, so N cannot change - therefore it is no use varying N and seeing if the function can be made smaller).
OK, thanks for the help.
But I still don't understand why we can't replace N with N=\sum_{i=1}^n N_i in the equation before we do the partial differentiation.
Note the first equation could be written
f(N_1,...N_n)=N\ln(N)-N + \alpha N + \beta E + N \sum_{i=1}^n (N_i \ln(g_i) - N_i \ln (N_i)-(\alpha+\beta \epsilon_i) N_i)
Where I've put the N outside the sum rather than the Ni's inside the sum. But the Ni's inside the sum are not treated as constants.
I understand that the partial derivatives mean keeping everything but the one variable constant. But there are equivalent ways of writing the same expression, which gives different answers after partial differentiation.
So I guess my question is, how would one know what form is the "correct one" to use before applying the partial differentiation?
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
