How Far Can a Man Climb a Ladder Before It Slides?
  • Thread starter Thread starter SoulkeepHL
    Wall
The discussion focuses on solving a physics problem involving a ladder leaning against a wall, with a man climbing it. The key equations derived include the balance of forces in both the x and y directions, leading to relationships between the normal forces and frictional forces. The maximum distance the man can climb before the ladder begins to slide is expressed as x = L(2u + 1)cos(theta). The solution involves careful substitution of values into the torque equation and understanding the balance of forces. The final answer provides a clear formula for determining the climbing distance based on the ladder's angle and friction coefficients.
SoulkeepHL
[SOLVED] Ladder on a wall problem
I'm stumped on this problem. I've solved for the distance the person can climb in terms of N(b), but I can't get N(b) in known terms.
A ladder of mass 2M and length 2L is kept on a rough horizontal floor and leaned against a rough vertical wall. The coeff. of static friction between both the wall and the ladder and the floor and the ladder is u. A man of mass M starts climbing the ladder. Find the maximum distance the man could climb (x) before the ladder starts sliding.
Point (a) is defined as the point at which the ladder contacts the floor, and (b) is defined as the point at which the ladder contacts the wall. theta (known) is given as the angle between the top of the ladder and the wall.
N = Normal Force
F = Friction
What I have so far is:
x dir: N(b)-F(a) = 0
N(b) = F(a)
y dir: F(b) + N(a) - 2Mg - Mg = 0
F(b) + N(a) = 3Mg
Torque about A:
N(b)*2L(cos(theta)) + F(b)*2L(sin(theta)) - 2Mg*L(sin(theta)) + Mg*x(sin(theta) = 0
So solving for x in the torque equation is trivial, but I can't get anything else (N(a), N(b), F(a) or F(b)) in terms of M and g. Any insight is appreciated.
Edit: And because its about to slide:
F(a)=uN(a)
F(b)=uN(b)
You will be heading toward a simultaneous equation.
THe total weight of man and ladder must be balanced by the upward normal force N(a) plus the static friciton agains the wall, which is uN(b).
The normal force against the wall must then be balanced by the static friction agains the ground uN(a).
So 3Mg = N(a) + uN(b)
N(b) = uN(a)
After analyzing the problem and using the given information, I was able to solve for the maximum distance the man can climb before the ladder starts sliding. Here are the steps I took:
1. First, I drew a free body diagram of the ladder and labeled all the forces acting on it.
2. Using the x-direction equation, N(b) = F(a), I substituted N(b) in the y-direction equation to get F(b) + F(a) = 3Mg.
3. Next, I used the torque equation and substituted F(a) = uN(a) and F(b) = uN(b).
4. Simplifying the torque equation, I got N(a) = 2Mg and N(b) = Mg.
5. Substituting these values in the y-direction equation, I got F(b) + 2Mg = 3Mg.
6. Solving for F(b), I got F(b) = Mg.
7. Substituting this value in the torque equation, I got x = L(u + 1)cos(theta).
8. Finally, to find the maximum distance, I set F(b) = uN(b) and solved for x, which gave me the final answer of x = L(2u + 1)cos(theta).
I hope this helps and clarifies any confusion you may have had. The key to solving this problem was using the given information and substituting it in the appropriate equations.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
