Derivative of a Taylor Series f(x) is unknown
Brilliant
If \sum_{n=0}^{\infty} a_{n}x^n is a Taylor series that converges to f(x) for all real x, then f'(1) = ?
A Taylor series:
\sum_{n=0}^{\infty} \frac {f^{(n)}(c)}{n!}(x-c)^n
and the dirv of a Taylor series:
f'(x)=\sum_{n=0}^{\infty} na_{n}(x-c)^{n-1}
I started by taking the derivative of the basic Taylor serie:
Then simply plugging in 1. I guess I was just thinking this is might be centered at 0, so I put in 0 for c, although the problem doesn't specify.
I end up with the expression:
f'(1)=\sum_{n=0}^{\infty}n\frac {f^{(n)}(0)}{n!}
At this point I'm not sure what to do because I don't know the function f(x). It seems like the answer should be numerical, but the question is quite vague. Maybe this is blatantly simple and I'm just failing to see it, but any tips would be appreciated.
I don't think the answer is numerical. Just differentiate the series and plug in x=1.
Interesting. It is an odd question.
So you think
\sum_{n=0}^{\infty} \frac {f^{(n)}(0)}{(n-1)!}
is all it's looking for?
Also, it seems like that should maybe be: f(n-1)(0). If you applied the chain rule when you differentiate, but then you would need to multiply by the derivative of the inside function? that I don't know?
EDIT:Actually maybe I'm just confused. :P
EDITEDIT: Yes, because the whole an term is constant, so no chain rule or anything funny?
Anyway, thanks.
I think you are over complicating this. If f(x)=a0+a1*x+a2*x^2+a3*x^3, then f'(1)=a1+2*a2+3*a3, right? It's the same problem but infinite.
Yes, you're right. I do this all the time. Thank you very much! Sometimes I just need to be slapped.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
