Derivative of angular velocity of rotating co. system
The discussion centers on the time derivative of angular velocity in a rotating coordinate system, emphasizing that it is not zero, contrary to initial claims. It explains how the time-dependent rotation matrix and the use of Cartesian coordinates lead to expressions for velocity and acceleration, incorporating inertial forces like Coriolis and centrifugal forces. The derivation shows that while a person in a rotating frame may perceive objects at rest relative to them as unchanged, they would indeed experience effects from changing rotation rates. The final equations of motion account for these inertial forces, which are crucial in applications like meteorology and aviation. Understanding these dynamics is essential for accurately describing motion in non-inertial frames.
Pushoam
What is time derivative of angular velocity ( measured w.r.t. an inertial frame ) of a rotating co. system w.r.t. the same rotating co. system?
I think a person sitting in a closed rotating box feels the an object at rest w.r.t. him as rest. He doesn't observe the angular velocity of the object changing.
So, the answer to the above question is 0.
Is this correct?
No. In the following I work with Cartesian vector and tensor components. The Einstein summation convention is used, i.e., you always have to sum over repeated indices from 1 to 3.
Let ##\vec{e}_j## denote a Cartesian coordinate system fixed in an inertial frame and ##\vec{e}_j'## one fixed in the rotating system. Then you have
$$\vec{e}_j'=D_{ij} \vec{e}_i,$$
where ##\hat{D}=(D_{ij}) \in \mathrm{SO}(3)## is a time-dependent rotation matrix. For the position vector you have
$$\vec{x}=x_j' \vec{e}_j'=D_{ij} x_j' \vec{e}_i \; \Rightarrow x_i=D_{ij} x_j'.$$
Now you get
$$v_i=\dot{x}_i=\dot{D}_{ij} x_{j}'+D_{ij} \dot{x}_j'=D_{ij} [\dot{x}_j+(D^{-1})_{jk} \dot{D}_{kl} x_l'].$$
Now since ##\hat{D}^{-1}=\hat{D}^T## you have ##\hat{D} \hat{D}^T=1## and thus ##\dot{\hat{D}} \hat{D}^T+ \hat{D} \dot{\hat{D}}^T=0## or
$$\hat{D} \dot{\hat{D}}^T=-(\hat{D} \dot{\hat{D}}^T)^{T}.$$
That means that the matrix ##\hat{D} \dot{\hat{D}}^T## is antisymmetric and thus we can express it with help of the Levi-Civita symbol via an axial vector, i.e.,
$$(D^{-1})_{jk} \dot{D}_{kl}=\epsilon_{jkl}\omega_k',$$
and thus
$$v_i=D_{ij} (\dot{x}_j' + \epsilon_{jkl} \omega_k' x_l').$$
Or writing the components as column vectors ##\underline{v}## etc. you get
$$\underline{v} = \hat{D} (\dot{\underline{x}}' + \underline{\omega}' \times \underline{x}').$$
Now in the same way you can take another time derivative, leading to
$$\underline{a}=\dot{\underline{v}} = \hat{D} [\ddot{\underline{x}}' + 2 \underline{\omega}' \times \dot{\underline{x}}' + \underline{\omega}' \times (\underline{\omega}' \times \underline{x}') + \dot{\underline{\omega}'} \times \underline{x}'].$$
Multiplying by the mass of the particle you get finally the Newtonian equation of motion in the rotating frame as
$$m \ddot{\underline{x}}'=\underline{F}' - 2m \underline{\omega}' \times \dot{\underline{x}}' -m \underline{\omega}' \times (\underline{\omega}' \times \underline{x}') -m \dot{\underline{\omega}'} \times \underline{x}'].$$
So despite the "true force" represented by the components ##\underline{F}'## wrt. the rotating basis you get three sorts of "inertial forces" which, as the derivation shows, comes from the rotation of the rotating frame wrt. the inertial frame. Sometimes one thus calls them also "fictitious forces", because you can get rid of them by transforming back into an inertial reference frame.
The inertial forces on the right-hand side of the final equation are called Coriolis force (2nd term), centrifugal force (third term). The fourth term has no special name, as far as I know, but it's due to the angular acceleration for the rotating reference frame wrt. the inertial frame. In the usual application of the motion of particles (or as important in meteorology fluids like the air) on Earth the latter force usually can be negected since the rotation of the Earth is with pretty constant angular velocity in first approximation. For motion close to the Earth also the centrifugal term has to be lumped into the effective gravitational force, approximated by ##m \underline{g}'##. So that you finally have for this special case
$$m \ddot{\underline{x}}'=m \underline{g}'-2 m \underline{\omega}' \times \dot{\underline{x}}'.$$
You can use this formula to calculate the free fall on the rotating Earth or the fascinating motion of the Fourcault pendulum.
Likes FactChecker
The time derivative calculated in a coordinate system whose rotational rate is changing would not include (detect?) it's own rotational acceleration.
A person would certainly feel it if he was in a box whose rate of rotation changed. He would have to explain the difference between the physical force he feels and any time derivatives he calculates in the box coordinates.
The equations of motion that are used to understand the flight of an airplane have to take all the rotational accelerations into account in the calculations.
Likes Pushoam
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
