Derivative of multivariate integral
supaveggie
Trying to figure our how to solve the following: \frac{dW}{dσ}
where W(σ) = 2π\int_0^∞y(H(x,σ))x,dx
both y and H(x,y) are continuous functions from 0 to Infinity
Tried using the leibniz rule but it's not really getting me anywhere...
\frac{dW}{dσ} = 0+0+2π\int_0^∞\frac{\partial(y(H(x,σ))x)}{\partial \sigma},dx
I'm not familiar with a chain rule for partial differentiation...
The solution I have is showing
\frac{dW}{dσ}= 2π\int_0^∞y'(H(x,σ))\frac{dH(x,σ)}{dσ}x,dx I'm not understanding how they arrived at this.
It is also unclear what y' represents as ' is not necessarily used for derivative or defined anywhere...
Thanks
where W(σ) = 2π\int_0^∞y(H(x,σ)x,dx
Thanks
Assuming nice enough conditions on H and the convergence of the improper integral (which I haven't checked), I would expect$$
W'(\sigma) = 2π\int_0^∞y\frac{\partial(H(x,σ)}{\partial \sigma}x,dx$$
Thanks
The syntax is wrong, there is a missing ). Also, I see no attempt. And what is H?
updated the original post. Not seeing why the partial was pushed through the function y
Hint: let ##f(x, σ) := y \circ H##.
I think this is about as much help as I can give. Best of luck.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
