Derivatives and integrals help
The discussion revolves around the differentiation of an integral with variable limits, specifically from \( e^t \) to \( t^5 \) of the function \( \sqrt{8+x^4} \). This falls under the subject area of calculus, focusing on the application of the Fundamental Theorem of Calculus and the chain rule.
  • Mixed
  • Participants explore the use of the chain rule and the Fundamental Theorem of Calculus to differentiate the integral. Questions arise regarding the application of a specific formula for differentiation of integrals with variable limits. There is also inquiry about how to apply the derivative of the anti-derivative function within the context of the problem.
Some participants have provided insights into the differentiation process, referencing the necessary formulas and the relationship between the integral and its limits. However, there remains a lack of consensus on the specific steps to take, with participants seeking clarification on how to apply the discussed concepts.
Participants express urgency due to an upcoming calculus final, which may influence the depth of their inquiries and the clarity of their understanding. There is also a mention of a specific formula for differentiation that some participants are unfamiliar with, indicating a potential gap in knowledge that is being addressed through discussion.
polulech
derivative of integral over e^t to t^5 (sqrt(8+x^4)) dx
I know I need to use the chain rule and I can take the derivative of the integral without respect to e^t and t^5. If you know the answer, can you answer and tell me how to do it?! Calculus final on Monday...
Have you never seen the formula [tex]\frac{d}{dt}\int_{A(t)}^{B(t)} f(x,t) dx =<br /> \frac{dB(t)}{dt} \left. f(x,t)\right|_{x=B(t)} <br /> - \frac{dA(t)}{dt} \left. f(x,t)\right|_{x=A(t)} <br /> + \int_{A(t)}^{B(t)} \frac{\partial f(x,t)}{\partial t} \, dx ?[/tex]
RGV
Umm no I have not :(
How do I put the pieces from my integral into that?
Hi polulech. Welcome to PF.
Suppose F(x) is the anti-derivative of [itex]\displaystyle \sqrt{8+x^4\,}\,.[/itex]
Then by the fundamental theorem of calculus, [itex]\displaystyle \int_a^b\sqrt{8+x^4\,}\,dx=F(b)-F(a)\,.[/itex]
In the case of your integral you have: [itex]\displaystyle \int_{e^t}^{\,t^5}\sqrt{8+x^4\,} \,dx=F(t^5)-F(e^t)\,.[/itex]
You know that [itex]\displaystyle \frac{d}{dx}F(x)=\sqrt{8+x^4\,}\,.[/itex] Combine this result with the chain rule to find the derivative of your integral.
how would I do that
polulech said:
how would I do that
Can you find [itex]\displaystyle \frac{d}{dt}F(t^5)\,,[/itex] if you know that F'(x)=√(8 + x4) ?
would i plug t^5 into the √8+x^4 and then calculate the derivative?
No.
F(x) is a function whose derivative is √(8+x4).
The chain rule says that [itex]\displaystyle\frac{d}{dt}F(t^5)=F\,'(t^5)\cdot \frac{d}{dt}(t^5)\,.[/itex]
Furthermore, [itex]\displaystyle F\,'(t^5)=\sqrt{8+t^{20}}[/itex]
  • · Replies 23 ·
  • · Replies 105 ·
12K
