Derivatives of inverse trig functions
4 replies · 6K views · last reply
BuBbLeS01
find an equation of the tangent line to graph of f at the indicated point.
f(x) = arcsin2x
(u'/sqrt 1-u^2)(2)
2. The attempt at a solution
(1/sqrt 1-2x^2)(2)
I got the answer from calcchat but I don't understand where the 1 and 2 came from?
Let [tex]y=sin^{-1}2x=> siny=2x[/tex] can you do implicity Differentiation?
or here is a formula to know
[tex]\frac{d}{dx}(sin^{-1}X)=\frac{1}{\sqrt{1-X^2}}[/tex]
and because you know that formula...you can use the chain rule
Okay I thought the formula was...
u'/sqrt 1-u^2
so can u bring it up so its 1-(1-x)^-1/2?
u'/sqrt 1-u^2
[tex]\frac{1}{\sqrt{1-X^2}} ={1}{(1-X^2)^{\frac{1}{2}} =(1-X^2)^{\frac{-1}{2}}[/tex]
because [tex]\frac{a}{b^n} = a*b^{-n}[/tex]
u'/sqrt 1-u^2
Obviously, if u= x (and the differentiation is with respect to x) then u'= 1 so the two formulas are the same. The formula you give is more general. If u is any function of x (and the differentiation is with respect to x) then
[tex]\frac{d arcsin(u(x))}{dx}= \frac{ \frac{du}{dx}}{\sqrt{1- u^2(x)}}[/tex]
