How to Derive Delta_c/c for a Given Equation?
  • Thread starter Thread starter garyman
    Derive Expression
garyman
If an equation has the form c = A + Bt - Ct^2 + Dt^3 + Ez
Where A,B,C,D and E are known constants, t and z are the variables. t=15 and z=2. Derive an algebraic expression for delta_c/c in terms of delta_z/z and delta_t/t.
Apparently you are suppose to calculate delta_z, delta_t and delta_c and then use your value for c (which was calculated using the values of z and t) to get a value for delta_c/c but i haven't a clue where to start.
Any advice would be much appreciated..
Yes, first calculate c when t= 15 and z= 2. Then do the same thing except use t= 15+ deltat, z= 2+ deltaz so you get a another value of c which will depend on deltat and deltaz. deltac will be the difference between those two values and deltac/c is that difference divided by your first value for c.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
