Derive the equation for kinetic energy and gravitional energ
In summary: Cancels out in terms of the motion of the mouse, but not in terms of the elastic PE (which is what the question asks...).
Derek1997
63
A wooden toy mouse of mass (m) is attached to a spring with constant (k) and suspended vertically as shown below. The toy is released at the point the spring is unstretched at position x = +A, passes through equilibrium at x = 0 and the spring’s maximum extension occurs at x = -A. If we ignore air friction and assume an ideal spring calculate expressions for the kinetic energy Ek, the elastic potential energy E elast, the gravitational potential energy E pot,and the total energy of the system Etotal, at (i) the release point and (ii) the equilibrium point. Take the gravitational potential energy to be zero at the equilibrium point y=0 and note that for a mass on a spring the maximum velocity vm=wA where w= sqrt (k/m)
pe=1/2kx^2
e=mgh
X= acoswt
K=mw^2
For equilibrium, I wrote for kinetic expression, since equation is 1/2 kx^2 i substitued the equation k mw^2, and since x was 0 and i canceled the term and derived the equation 1/2 mw^2. Could you please tell me if I am right?
That is not at all clear. Please clarify which part of the question you are discussing and post your detailed working.
Hi thanks for reply,
so in regards to equilibrium point one, where x=o what i did was, i derived the equation for potential energy as PE= 1/2kx^2 where x=0 thus the whole equation would be zero and we don't need to worry about it.
So i used kinetic energy which yeilded me KE=1/2 mv^2, substituing, v as sqrt (k/m), thus:
KE= 1/2m*sqrt(k/m)*A
thus the total energy at equilibrium point would only depend on kinetic energy, which is E tot= KE which is the equation above.
am i following correct method?
It asks specifically for the elastic potential energy first, so I assume that is what you mean here.
It specifies x as being measured from the equilibrium point. Is the elastic PE really zero there?
well x=0, so by that it would make the whole equation to 0?
It makes your equation 0, but that is not what I asked. What is happening to the spring at the equilibrium point? Does it really have no elastic PE?
i think so. well how can it have it when it's 0?
Your equation says it is zero. I am challenging your equation.
What is meant by "equilibrium point" in this context?
where it remained same, no upward or downward motion, could you please check if i have a right answers? if it is i can send you the second part.
Where it can remain static, yes... it is not necessarily static there ... and what will be the forces acting on it at that point?
gravitional potential and normal force? but don't you just need to state the equation?
Gravitation, yes, but not potential - a potential is not a force.
What do you mean by normal force here? The toy mouse is not on the ground.
yea true sorry. mouse is not on the ground.
So, ik gravition is the force but what does it do with equation?
You claim that the elastic PE is zero at the equilibrium point. I am trying to prove to you that it is not, so your equation is wrong.
If gravity is acting, how come it is an equilibrium point? What is balancing the gravity?
tension on the spring? balances it.
Right. If there is tension in the spring, how can it not be storing any elastic energy?
yea but they don't balance out by gravitational energy?
btw am i right with the kinetic energy one??
Sure, but the question asks specifically for the elastic PE at equilibrium. It is equal and opposite to the gravitational PE (measured from the initial position), but it is not zero.
so cancells out?
Derek1997 said:
so cancells out?
Cancels out in terms of the motion of the mouse, but not in terms of the elastic PE (which is what the question asks for).
1. What is the equation for kinetic energy?
The equation for kinetic energy is Ek = 1/2 * m * v2, where Ek is the kinetic energy in joules (J), m is the mass in kilograms (kg), and v is the velocity in meters per second (m/s).
2. How is kinetic energy related to velocity?
Kinetic energy is directly proportional to the square of the velocity. This means that as the velocity increases, the kinetic energy will also increase. Conversely, if the velocity decreases, the kinetic energy will decrease as well.
3. How does gravitational energy factor into the equation for kinetic energy?
The equation for kinetic energy only accounts for the energy of an object in motion. Gravitational energy, on the other hand, is the potential energy an object has due to its position in a gravitational field. In order to fully calculate the total energy of an object, both kinetic and gravitational energy must be considered.
4. What is the relationship between kinetic energy and mass?
The equation for kinetic energy shows that kinetic energy is directly proportional to mass. This means that as the mass of an object increases, the kinetic energy will also increase, assuming the velocity remains constant.
5. Can the equation for kinetic energy be used for any object in motion?
The equation for kinetic energy can be used for any object in motion, regardless of its shape or size. However, it is important to note that this equation assumes that the object is moving in a straight line and that there are no external forces acting on it.
