Deriving a differential equation for car motion
To derive a differential equation for a car shifting into neutral, it's essential to consider the initial velocity, air drag, and frictional forces. Gravity affects tire traction but is less significant if the tires are rotating freely without braking or acceleration. Friction in the wheel bearings is also a factor but secondary to air drag. Accurately parameterizing air drag will simplify the modeling process. Overall, focusing on these forces will provide a realistic representation of the car's motion.
cytochrome
I'm looking at this scenario where a car is moving and then shifts into neutral. Knowing the initial velocity, how can I derive a differential equation?
I know the air drag and the frictional force... are there any other forces, like gravity, that should be included to make it realistic? I don't understand what a downward gravitational force would do for this problem
"Downward gravitational force" (weight) would affect the tire traction. But if you are assuming the tires are rotating freely and not dragging on the ground (no braking or acceleration), that should not be an issue. There will, of course, be friction in the wheel bearings.
The dominant force is going to be the air drag. That should make things easy for you, if the air drag can be parameterized accurately.
Chet
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
