Deriving an Equation from a graph
  • Thread starter Thread starter Murdoc88
    deriving Graph
The discussion focuses on deriving an equation from a graph of centripetal force versus frequency. The user is struggling with creating a linear plot from their data, specifically needing to relate centripetal force to the square of frequency. It is clarified that the relationship can be expressed as Fc = kf^2, where k is a constant representing the slope of the linear graph. The user must hand-draw the graph and cannot use software like Excel for their assignment. Overall, the conversation emphasizes the importance of understanding graphical relationships in physics.
Murdoc88
Hello everyone,
I'm in need of some assistance in regards to deriving an equation from a graph. I have been tasked to graph information which I've collected through experimentation and then write an equation to represent the graph.
1 Plot a graph of centripetal force versus frequency ( frequency is the independent variable)
2 Using graphical analysis, rearrange the values of the frequency until a linear plot is obtained. Include a table of values.
3 Write a proportionality statement (in words) relating the centripetal force and frequency
4 write the equation relating centripetal force and frequency, inclued the value of the constant and units.
5 using the eq^, determine the force (including units and direction) required to maintain a stoppers (item swung) of the same mass in a horizontal circle of radius 1.0 m with a frequency of 6 Hz. a complete solution is required
I'm stuck at steps 3 and 4 and I am not really sure on how to approach the questions. I know that I have a power graph and if I square the frequencies that I obtained I come to a linear graph.
Here is a direct link to the graphs that I've made:
http://s7.photobucket.com/albums/y266/murdoc8888888/?action=view&current=hmwrk2.jpg
Fc=(mv^2)/r
f= 1 / T
I'm not exactly sure on how to derive an equation from curved graph at all, the linear graph though is simple.
(Y2 - Y1) / (X2 - X1)
is the equation to find slope and from there I would use 'y' intercept form and derive that equation.
I don't know how to do this with a power graph though.
Firstly, you only need to derive an equation from linear graph (the one with the straight line), not the curved one. So looking at you graph, you have a (roughly :s) straight line when you plot Fc vs. f2 and therefore you can say that that Fc\proptof2. Now, you should be able to write an expression with a constant of proportionality, and what is the general expression for a straight line...?
Well the general expression for a straight line is Ax + By + C = 0, or y = mx + b.I know it's a very rough linear graph but my teacher only wants the use of whole numbers such as 2 or 3 rather than decimals as exponents. So from here how would I write the proportionality statement of Fc\proptof^2 using the equation of the linear graph?
Fc\proptof^2 if I remember correctly, becomes an equation such as Fc = Kf^2 where K is a constant. Is this true?
P.S. I'm new to the latex system so please bare with me ...
Well, on your straight line graph, what is represented by "y" in y=mx+b?
What is represented by "x" in y=mx+b?
y is the same as f (x) where f is centripetal force, and x represents frequency. So could I then say that Fc(frequency) = mx + b ? or am I missing something here?
I was just wondering if my logic is correct.
Your very close but not quite there. What did you plot on your linear graph? Did you really plot Fc vs. f, or did you plot Fc vs. f2...?
Alright,
Fc v f^2 becomes an equation when you add a constant. I'll make it 'k', would 'k' then represent the slope of the linear line?
Fc = kf^2 ?
Looks good to me :approve:. Depending on your data you may have to add in a constant (which would be the y-axis intercept + C), but this constant would be due to the standard error of your data. And yes k would represent the gradient of the line, if you have a proper line fitting program I would use that, but failing that excel does a reasonable job of plotting lines of bet fit.
P.S. What is your academic level?
I'm not sure what you mean academic level. I'm currently a senior student in high school.
Then my guess would be the line of best fit drawn by excel would be sufficient for High School level, but it might be worth checking with your teacher. :smile:
I see I see,
Nope my teacher won't accept excel, it needs to be hand drawn.
Thanks for the help!
Murdoc88 said:
I see I see,
Ahh, the fun of hand plotting graphs It was a pleasure :smile:
