Deriving Energy Levels of a Particle in a Box
The discussion focuses on deriving the energy levels of a particle in a box using stationary waves, with the formula E = h^2n^2/8ml^2 being confirmed as correct. Participants clarify that using classical mechanics concepts like E=1/2mv^2 is inappropriate in quantum mechanics, as frequency and wavelength have different meanings than in classical physics. The importance of stationary states is emphasized, noting that the wavefunction must be zero outside the box, leading to specific boundary conditions. The confusion around the relationship between energy, frequency, and wavelength in quantum mechanics is addressed, highlighting the need for careful interpretation of these terms. Overall, the conversation underscores the distinction between classical and quantum mechanical approaches to particle behavior.
binbagsss
Deduce the formula giving the energy levels in terms of n for a free particle in a box of length l, using the fact that only stationary waves can be occupied by the particle.
- considering stationary waves, λ = 2l/n. (1)
1) Using E=hv/λ= hvn (2)
And
P = h/λ, v = h/m*λ, v = hn/2ml (3)
Subbing this into (2), E = h^2n^2/4ml^2
2) However using E=1/2mv^2, p=mv, and λ = h/mv,
1/2mv^2= p^2/2m = h^2/λ^2*2m
= h^2/2m * n^2/4l^2 ( applying (1) )
= h^2n^2/8ml^2
I’m confused as to why this is - is there something fundamentally wrong with trying to derive the energy levels for a particle in a box using 1/2mv^2=E and p=mv ?
Thanks a lot anyone - greatly appreciated :D.
what you've got there isn't E=\frac{1}{2}m v^2
check your working
also 'only stationary waves can be occupied by the particle.' isn't specifically true, if you have a superposition of energy eigenstates then the wave certainly isn't stationary
Yes, this is right. But really the technical term is 'stationary state'.
binbagsss said:
1) Using E=hv/λ
Where did this come from? Did you use E=hf and then substitute f=v/λ? This does not work in quantum mechanics.
= h^2n^2/8ml^2
This is the right answer.
BruceW said:
Yes, this is right. But really the technical term is 'stationary state'.Where did this come from? Did you use E=hf and then substitute f=v/λ? This does not work in quantum mechanics.
Ahh, thank you. Why is this? Is c= alanda*f derived from : E^2=(mc^2)^2+(pc)^2 and E=hf and p=h/alanda
Whereas for particles, due to their mass, once arranging all of the above, the product of alanda and f will not equal its speed.
Because the wave function of the particle must be zero outside the box (the walls of the box are impregnable, and the particle cannot be found outside the box, so the probability for finding it must be zero everywhere). Since the wavefunction ought to be a continuous function (a postulate in Schroedinger's Wave Mechanics), it must be zero on the ends of the box as well.
Inside the box, the particle is free and is described by a single wavelength standing wave.
Since the wave has 2 nodes at the ends of the box, there must be an integer number of half-wavelengths of the standing wave accommodated on the length of the box, i.e.:
<br /> n \, \frac{\lambda}{2} = l \Rightarrow \lambda = \frac{2 l}{n}, \ n = 1, 2, \ldots<br />
That's not really the reason. Remember, you used non-relativistic physics for your particle in a box question, and f=v/λ still did not work.
The reason that it doesn't work in quantum mechanics is because 'frequency' and 'wavelength' don't have the same meaning as they do for classical waves (confusing, I know). In quantum mechanics, you should simply think of the 'frequency' as telling us about the energy of the particle, and the 'wavelength' as telling us about its momentum.
Having said that, there can be a strong connection between the classical frequency of motion and the energy of the analogous quantum state. For example, in the quantum harmonic oscillator, the energy is quantised by hf (where f is the classical frequency of motion).
So in summary, I'd say be careful with the quantum frequency, its proper definition is to do with the energy of the system, not the classical frequency.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
