Deriving formula for force by thought experiment
The discussion revolves around deriving a formula for force through a thought experiment involving the impact of a punch on a round ball on a flat surface. Participants explore the relationship between force, displacement, mass, and other factors such as friction and impulse, questioning the validity of the proposed formula F = md.
  • One participant suggests that force is proportional to displacement (d) and inversely proportional to mass (m), leading to the formula F = md, but acknowledges potential flaws in this reasoning.
  • Another participant proposes using spring displacement instead of a round ball to derive force in proportion to displacement.
  • Concerns are raised about the assumptions made regarding the characterization of impact strength as "force," with mentions of impulse and work as alternative considerations.
  • It is noted that the distance a ball travels depends on energy transferred rather than just the force applied, highlighting the role of friction and the duration of the impact.
  • Participants discuss the vector nature of force and its implications in scenarios like circular motion, where force and velocity are orthogonal.
  • Questions arise about the relationship between force and the distance a ball travels, with some arguing that greater force does not necessarily result in greater distance due to various factors.
Participants express differing views on the relationship between force, displacement, and mass, with no consensus reached on the validity of the proposed formula F = md. The discussion remains unresolved with multiple competing perspectives on the nature of force and its implications.
Limitations include assumptions about the impact of friction, the dependence on definitions of force and impulse, and the unresolved mathematical relationships between force, distance, and energy transfer.
Boltzman Oscillation
TL;DR
Was thinking of how I can derive force from a simple thought experiment but I came up with F = md where d is displacement. Why can it not be this?
Hi all, I was thinking punching a round ball on a flat surface and seeing how I could determine a formula for force from it. I thought the following:
1. The ball will go further the harder I punch and thus force must be proportional to displacement d.
2. Ball will go further if it is lighter thus force is inverse proportional to m.
This I came up with F = md. If I experimented I would assume to get the wrong answer since force is F=ma in classical physics. So I came up with the following to challenge the outcome of F=md:
1. displacement does not take into consideration friction.
2. Even if the formula was correct then it would be useless for determining gravity as the ball would eventually be stopped by the ground and if there is no ground and the ball was falling forever then the displacement would be infinite and the force would be infinite. This brings us back to 1 if we see the ground as 100% friction and no ground as 0% friction.
Are there any other ideas I'm missing as to why F != md?
If you choose not a round ball but spring displacement for your thought experiment, you will be able to get force in proportion to d.
I feel like you've done this backwards. Instead of asking why ISN'T force proportional to MD, ask why force IS proportional to MD. Otherwise the only real answer you can get is, "That's not how nature works".
This way, if you do find a situation in which f=md, you only have one situation to describe, not an infinite number of examples or explanations of why it doesn't.
You are assuming that the strength of the impact of fist on ball is characterized by "force". It is not.
If one multiplies (actually integrates) the force of the impact by the duration of the impact, one can get "impulse" -- the amount of momentum transferred.
If one multiplies (actually integrates) the force of the impact by the distance traversed during the impact, one can get "work" -- the amount of energy transferred.
Interesting, I should be asking why something is and not isn't in order to reduce the answers. Thank you for the advice!
I'm sorry are you saying that the strength of the impact is not related to force? What do you mean by that? If I hit a ball with more force than someone else did to a similar ball than my ball would go further would it not?
Ah, another classic problem. Thank you, I will try to work this one out similarly and see what I can get.
Not necessarily. It depends on more than just a single number for force.
For a ball projected on a flat surface with kinetic friction, the distance traveled will scale with energy transferred. A fellow applying a small force with a shuffleboard stick can get as much distance as another fellow applying a large force with a hammer.
What matters is the force integrated over the collision duration, not the maximal value of force reached.
It would have a greater acceleration. That's Newton's second law.
Force is a vector:
Explain circular motion, where force and velocity are orthogonal.
Distance is frame dependent. If you hit something that's already moving It may stop.
Without friction or orher retarding forces, the total distance is infinite for any force given as a single impulse.
The units are wrong.
No. Strike a cannonball with a hammer and see how far it goes. The answer is almost nowhere even though the instantaneous force of the strike was large.
Now shoot the cannonball from a cannon. The pressure on the ball acts for the whole time the ball is in the barrel. But the maximum force on the ball may be less than the maximum with the hammer.
As others said, force times time is what counts. Not force alone. If the force varies with time, then force times time becomes the integral of force with respect to time.
I see what you mean. Thank you.
  • · Replies 17 ·
  • · Replies 35 ·
  • · Replies 29 ·
  • · Replies 64 ·
