Deriving heat capacity using thermodynamics identity
5 replies · 17K views · last reply
ultimateguy
Use the thermodynamic identity to derive the heat capacity formula [tex]C_V=T\frac{\partial{S}}{\partial{T}}_V[/tex]
[tex]C_V=\frac{\partial{U}}{\partial{T}}[/tex]
[tex]T=\frac{\partial{U}}{\partial{S}}[/tex]
dU=TdS-PdV+[tex]\mu[/tex]dN
I used [tex]C_V=\frac{\partial{U}}{\partial{S}}\frac{\partial{S}}{\partial{T}}=T\frac{\partial{S}}{\partial{T}}_V=\frac{\partial{U}}{\partial{T}}=C_V[/tex].
This is the only solution I can think of, but I don't think I used the thermodynamics identity, did I?
There are a distinct lack of thermal physicists on this website and with good reason as it is one of the most boring subjects ever. I think if you know that:
[tex]dS=(\frac{\partial{S}}{\partial{U}})_{PV}dU[/tex]
Then you can substitute the following into the equation for dU,
[tex]dU=(\frac{\partial{U}}{\partial{T}})_VdT[/tex]
and have a fiddle about, that should set you off on the right lines.
This may be a dumb question, but what's the difference between E and U?
There is none. I apologise. I normally write E and I was trying to conform to your notation but obviously forgot half way through I will change it.
I'd have thought if they wanted a derivation from the thermodynamic identity then they'd want you to start from that. However the OP proof might be accepted.
