Deriving the ∫dω1 integral in 2nd-order polarization
4 replies · 2K views · last reply
Ngineer
Starting with the second order polarization in the time domain:
Equation for second-order polarization in the time domain: P_i^(2)(t) equals a double integral of chi_ijk^(2)(t - t', t - t'') times E_j(t') times E_k(t'') with respect to t' and t''.
(1)
I am trying derive the frequency domain form:
Equation P_i^(2)(ω) = ∫dω1 χ_ijk^(2)(ω; ω1, ω2) E_j(ω1) E_k(ω2), with a brace under the product marking ω = ω1 + ω2.
(2)
Multiple sources give essentially the same formula with the same integral, I have obtained the particular ones in here from those lecture notes.
My issue is finding the origin of the ∫dω1 integral. After a day of attempts I still can't figure out how it comes into play.
The attempt at a solution
Attempt 1
I started by identifying the time-domain formula (equation 1) as a double convolution:
Expression (χ_ijk(t) ⋆ E_j(t)) ⋆ E_k(t), where ⋆ denotes convolution, written as a nested double convolution of a susceptibility tensor element with two electric field components.
Which would map nicely to
Equation chi_ijk(omega) E_j(omega) E_k(omega), where chi is the second-order susceptibility tensor with indices i, j, k and E is the electric field at frequency omega.
But I did not get far as to deriving equation 2 from here.
Attempt 2
Another approach I have attempted is that recognizing the the desired frequency-domain form (equation 2) is very close to convolution with respect to ω=ω1+ω2:
Frequency-domain expression: chi_ijk(omega) star E_j(omega) star E_k(omega) equals the double integral from minus infinity to infinity over d omega_1 and d omega_2 of chi_ijk(omega) E_j(omega minus omega_2) E_k(omega minus omega_1).
However,
- Why would a convolution in the time domain map to a convolution in the frequency domain?
- The original formula (equation 2) does not have an integral with respect to ∫dω2.
Any help is incredibly appreciated.
Thank you!
  • Equation P_i^(2)(ω) = ∫dω1 χ_ijk^(2)(ω; ω1, ω2) E_j(ω1) E_k(ω2), with a brace under the product marking ω = ω1 + ω2.
  • Equation for second-order polarization in the time domain: P_i^(2)(t) equals a double integral of chi_ijk^(2)(t - t', t - t'') times E_j(t') times E_k(t'') with respect to t' and t''.
  • Expression (χ_ijk(t) ⋆ E_j(t)) ⋆ E_k(t), where ⋆ denotes convolution, written as a nested double convolution of a susceptibility tensor element with two electric field components.
  • Equation chi_ijk(omega) E_j(omega) E_k(omega), where chi is the second-order susceptibility tensor with indices i, j, k and E is the electric field at frequency omega.
  • Equation: chi_ijk star E_j star E_k equals the integral from minus infinity to infinity of d omega chi_ijk(omega) E_j(omega - omega_2) E_k(omega - omega_1).
  • Equation: chi_ijk(omega) star E_j(omega) star E_k(omega) equals the integral from minus infinity to infinity of d omega chi_ijk(omega) E_j(omega - omega_2) E_k(omega - omega_1).
  • Frequency-domain expression: chi_ijk(omega) star E_j(omega) star E_k(omega) equals the integral from minus infinity to infinity of d omega chi_ijk(omega) E_j(omega - omega_2) E_k(omega - omega_1).
  • Frequency-domain expression: chi_ijk(omega) star E_j(omega) star E_k(omega) equals the double integral from minus infinity to infinity over d omega_1 and d omega_2 of chi_ijk(omega) E_j(omega minus omega_2) E_k(omega minus omega_1).
How is your Fourier transform defined?
Assuming it is
##E\left(t\right)=\frac{1}{2\pi}\int d\omega \exp\left(-i\omega t\right) \tilde{E}\left(\omega\right)## Eq.(1)
##\tilde{E}\left(\omega\right)=\int dt \exp\left(i\omega t\right) E\left(t\right)##
Where ##\tilde{\dots}## denotes the frequency domain functions.
How about substituting Eq. (1) into your expressions, and then carrying out the integrals with respect to ##t'## and ##t''##? In the process of doing this you will need to explain what does ##\chi^{2}\left(\omega, \omega_1, \omega_2\right)## mean. How does it relate to temporal version?
Thank you for your response, the definition of the Fourier transform is
Multidimensional Fourier transform definition: chi tilde of omega 1 through omega N equals the product over s from 1 to N of the integral from minus infinity to infinity of dt_s, times chi of t_1 through t_N, times e to the i times the sum over s of omega_s t_s.
The derivation checks out if it is assumed to be separable with respect to t' and t''
  • Multidimensional Fourier transform definition: chi tilde of omega 1 through omega N equals the product over s from 1 to N of the integral from minus infinity to infinity of dt_s, times chi of t_1 through t_N, times e to the i times the sum over s of omega_s t_s.
So does it settle your question then? If there are still problems can you show how far you got before getting stuck?
Yes. I have actually corresponded with the professor that posted the online lectures I linked in the original post, and he kindly answered in detail, so I marked this post as solved.
Thanks for your kind help.
