Dethrone said:
I completely guessed that, because x^2 + y^2 defines a circle and x^2 + y^2 + z^2 makes no sense to me. I also find this hard to visualize. Also, does that mean I = ∑ mx^2 doesn't apply for more than two dimensions? Since it tells me I need to square the distance.
mx^2 generally only applies for a one dimensional object. So, for example, the very thin rod is approximately one dimensional object, since it is very thin.
Dethrone said:
Z bound: integral from 0 to L
Y bound: integral from -pi/2 to pi/2 (no idea)
X bound: integral from -sqrt(r^2- y^2) to + sqrt(r^2- y^2) (no idea)
I haven't been taught integration yet, so I don't think I'll be able to get the bounds. Everything I know about it right now are just self-learned. And I'm not required to know how they're derived yet, but it really bugs me to not fully understand it.
the x bound and z bound should be swapped around, since the z axis is the axis that the rod spins around. But once you've swapped around the x and z bound, you will have the correct bounds for both of them. And for y bounds, you just need the two extreme values for y. And remember to integrate over the bounds -sqrt(r^2- y^2) to + sqrt(r^2- y^2) First, since this includes the y variable.
Or, you could change to cylindrical coordinates, which might make things easier. Anyway, you're fairly close to the answer. I think the important thing is to see how number 8 on the wikipedia page will approximately be the same as number 4, under a certain limit. If you can see that, then that is all you really need, to understand how the very thin rod is derived as a special limiting case of the regular rod.
also, there is nothing wrong with just doing the calculation in 1 dimension to begin with. If we assume the rod is very thin, then we immediately know that the distribution is approximately 1 dimensional. So we don't need to worry about the other two dimensions in calculating the answer. But you do need to use mass per length, instead of mass per volume, since for the 1 dimensional case, you are no longer integrating over volume, but are integrating over a length instead.
