Deriving the precession formula wp = Q/(I·w)
  • Level: Graduate
  • Thread starter Thread starter JolleJ
    Formula Precession
10 replies · 7K views · last reply
JolleJ
Please see this link first: http://en.wikipedia.org/wiki/Precession#Classical_.28Newtonian.29"
How do they get to the formula
[tex]\textbf{wp}[/tex] = [tex]\frac{Q}{I*w}[/tex]
I also note that I*w = L (angular momentum).
How do they get to that equation? I've thought and though, I just don't know how. I really hope that someone can give me a link to a deriation of it, or perhaps help me themselves.
Thanks in advance.
Try this: http://scienceworld.wolfram.com/physics/GyroscopicPrecession.html"
Wow! Thank you so much.
Just one thing though: In equation (4), the d0, what is that? Change in angle? And where does that equation (4) come from? Never seen it before? Why is that true? :s
I think I get it now actually. It is because the change as well as angle are inifitsmally small... :) Right? :D
Yes, that's it. And because the torque is perpendicular to the angular momentum.
Now that I looked it over more carefully, I'm not happy with that derivation that I linked. It seems a bit sloppy. I'll post my own version in a bit.
I was just about to post my own derivation, when I found this on hyperphysics (one of my favorite educational sites--I highly recommend it): http://hyperphysics.phy-astr.gsu.edu/hbase/top.html"
This is almost exactly what I would have written, so it saves me the trouble! If you have questions about this derivation, let me know.
Thank you once more. What I need is acutally a combination of the two. The first is good because it fits the precession of a bicycle wheel (which is what I need to explain), and the next is good because of the smart derivation.
I've tried to write it down, how I think I need it. But I'm not sure, if I did any errors... I would very much like if you could just quickly look it through?
Here's the link: http://peecee.dk/?id=85095" (danish upload site: Click "Download fil").
At the moment it hasn't got an illustration, I will make one however.
Thanks in advance, once again. :smile:
Oh, and a last question: Is this good argumentation:
If I call the angle v. Can I say this:
"It is obvious that
[tex]sin(v) = \frac{\Delta L}{L}[/tex]​
For infinitsimal small angles sin(v)=v, so that:
[tex]dv = \frac{dL}{L}[/tex]​
since the angle is small when delta L is small."
Thanks in advance.
It looks OK to me. Note that your "r" is the moment arm--I assume your bicycle wheel is oriented perpendicular to the vertical?
"It is obvious that
It is certainly true that for small angles [itex]\sin\theta \approx \theta[/itex], as long as the angle is in radians. But you can also argue directly that as [itex]\Delta L[/itex] becomes small it more closely approximates the arc length of a circle, thus [itex]\Delta L/L[/itex] becomes the radian measure of the angle.
