MHB Solve Quadratic Equation: $\mathcal{E}$ Experiment
  • Thread starter Thread starter Julio1
The discussion centers on the conditions under which the quadratic equation \( ax^2 + bx + c = 0 \) has two distinct real roots, specifically focusing on the coefficients \( a, b, \) and \( c \). For the equation to have real roots, the coefficients must be real numbers, and the discriminant \( b^2 - 4ac \) must be greater than zero. The choice of coefficients significantly impacts the probability of obtaining distinct real roots, with different distributions yielding varying results. For example, if coefficients are integers from a dice throw, the probability can be calculated, while complex coefficients drawn from a uniform distribution lead to a zero-probability event for real roots. The conversation emphasizes the importance of understanding the probability distribution of the coefficients in determining the nature of the roots.
Julio1
The $\mathcal{E}$ experiment consists in choosing the numbers $a, b$ and $c$. Describe the event $A \,= \,$ the equation $ax^2+bx+c=0$ has two distinct real roots.
Hi !, I have this problem, I understand that the roots of the equation are $x=\dfrac{-b\pm \sqrt{b^2-4ac}}{2a},$ i.e., $x_1=\dfrac{-b+\sqrt{b^2-4ac}}{2a}$ y $x_2=\dfrac{-b-\sqrt{b^2-4ac}}{2a},$ but I don't understand that more there that do. :confused:
Mathematics news on Phys.org
How are the coefficients chosen? The answer is going to depend on that (for instance, if they are integers chosen from a dice throw the probability is going to be computable from basic probability, but if they are complex numbers drawn from a uniform distribution then $A$ is a zero-probability event).
Hello Bacterius, Thanks !
For that the equation $ax^2+bx+c=0$ has real roots, the coefficients $a,b$ and $c$ must be reals. In other hand, if $a,b,c\in \mathbb{C}$ the equation has complex roots, but how solve now the problem?
That wasn't what Bacterius meant when he asked how the coefficients are chosen. What probability distribution is used? It can't be "uniform" because there is no uniform distribution over the entire real numbers.
In any case, the equation ax^2+ bx+ c= 0 has two distinct real roots if and only if the discriminant, b^2- 4ac, is greater than 0. The probability of that depends upon the probability distribution of a, b, and c.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
