Describing Set of Complex Numbers for which This Converges
Newtime
Describe the set of all z \in \mathbb{C} such that the series \sum_{n=1}^{\infty} (1-z^2)^n converges
Basic analytic techniques.
This is from a graduate complex analysis class, and I just have a feeling my answer is too obvious to be correct...
Basically, I used the necessary condition that the the sequence given by a_n = |(1-z^2)^n| must tend to 0 as n tends to infinity. In other words, we know the modulus of the terms must go to zero. Then, viewing the series as a geometric series, |(1-z^2)| < 1. From there it was a few simple steps to conclude the set is \lbrace z\in \mathbb{C} \: | \: 0<|z|<2 \rbrace.
Even as I read over this, it makes sense. But like I said, it's much too simple to be correct...what am I forgetting here?
Your 'simple steps' are wrong. Whatever they are. |(1-z^2)|<1 looks ok. 0<|z|<2 doesn't. z=3/2 doesn't converge. z=i doesn't converge. I'd write z in polar form and try that again.
The reasoning described for determining the conditions necessary is missing a detail as well. Just because an goes to zero does not mean that the series will converge necessarily. It only works in this case specifically because we have a geometric series (and you can write out an explicit solution for the partial sums to see that it does converge)
Ah of course! A silly mistake...thanks for pointing it out.
Actually, it wasn't a silly mistake. Upon revisiting this problem, for some reason I'm not seeing the answer. Where should I go after \vert 1-z^2\vert&lt;1 \leftrightarrow\vert 1- r^2e^{2i\theta} \vert &lt; 1? I've tried using the triangle inequality and I've also tried expanding into sine's and cosine's to no avail. I know this must have some relatively simple trick, but I don't know what...a nudge in the right direction would be greatly appreciated.
Newtime said:
Actually, it wasn't a silly mistake. Upon revisiting this problem, for some reason I'm not seeing the answer. Where should I go after \vert 1-z^2\vert&lt;1 \equiv \vert 1- r^2e^{2i\theta} \vert &lt; 1? I've tried using the triangle inequality and I've also tried expanding into sine's and cosine's to no avail. I know this must have some relatively simple trick, but I don't know what...a nudge in the right direction would be greatly appreciated.
-1 &lt; 1- z^{2} &lt; 1
-2 &lt; -z^{2} &lt; 0
0 &lt;z^{2} &lt; 2
0&lt; \left|z^{2} \right| = \left|z \right|^{2} &lt; 2
Can you complete it ?
0 &lt;z^{2} &lt; 2
Well your last line implies \vert z \vert &lt; \sqrt{2} but how can we get from \vert 1-z^2 \vert &lt;1 to -1 &lt; 1-z^2 &lt;1? The modulus of complex numbers and the absolute value of real numbers do not share this property.
You are quite right about that. Write z=r*exp(i*theta) and try to write out what |1-z^2|<1 means in terms of r and theta.
I need to stop browsing for the day. I am posting nonsense. Please, forgive my incorrect solution.
I do not know what possessed me to make such a claim.
I was even ordering complex numbers .
Right. So I have \vert 1-r^2e^{2i\theta} \vert &lt; 1. This is where I get stuck. In real calculus one can easily get rid of those pesky vertical bars, but here, I don't know where to go. Like I said above, I've tried invoking the triangle inequality but I come to something which doesn't help since it is a lower bound. I've also tried expanding the inside of the modulus into sine's and cosine's but that gets messier, then a little nicer, then messier.
Don't worry about it; I appreciate your help. And after all, it's almost the same error I made to begin with!
Yes, expand the inside in terms of sin's and cos's. You want to use that if a and b are real then |a+bi|=sqrt(a^2+b^2).
Having solved the problem (finally), I see now my main (very, very silly) mistake: r^2e^{2i\theta} = r^2e^{i(2\theta)} = r^2(cos(2\theta) + isin(2\theta)) \neq r^2(cos^2(\theta) + isin^2(\theta)) which is the expansion I had been doing. So, it turns out the set is the interior of a lemniscate whose equation is immediate upon *properly* expanding into sine's and cosine's. Thanks for the help everyone.
