Understanding Saturated Sets in Quotient Maps
In summary, a subset C of X is saturated with respect to a surjective map p:X→Y if it contains every set p-1({y}) that it intersects. This means that if p-1({y}) is nonempty, then all of its elements must be in C. Any subset of Y can be used for this condition to hold, and other equivalent forms include C=p^{-1}(p(C)) and C being the union of equivalence classes.
hideelo
91
I am reading munkres topolgy and I am struggling with understanding the following sentence:
"We say that a subset C of X is saturated (with respect to the surjective map p:X→Y) if C contains every set p-1({y}) that it intersects"
if you have the second edition its in chapter 2 section 22 (page 137)
It's not that I have questions on it I just can't seem to make heads or tails of that sentence.
any help would be appreciated
All it means is that if C intersect p-1({y}) is nonempty, then C actually contains all of p-1({y}). So if C is saturated and p-1({y}) has say, two elements, it is not possible that only one of those elements is in C.
This is equivalent to "C is a saturated subset of X if C is the preimage of some subset of Y".
Likes 1 person
thanks
do we make any demands on the subset of Y, need it be open, closed... or will any subset do?
hideelo said:
thanks
Any subset will do.
Likes 1 person
hideelo said:
thanks
Another equivalent form is that ##C## is saturated if and only if ##C=p^{-1}(p(C))##. So the exact form of the subset of ##Y## is ##p(C)##.
That said, I prefer dealing with quotient mappings in terms of equivalence relations. Thus a quotient map ##p:X\rightarrow Y## induces a equivalence relation on ##X## given by ##x\sim x^\prime## if and only iff ##p(x) = p(x^\prime)##. The set of all equivalence classes can then be identified wuth ##Y##.
In that form, we can give new equivalent forms of saturated sets. One such form is to say that a set ##C## is saturated iff it is the union of equivalence classes. Another form is to say that ##C## is saturated if for any ##x\in C## and ##y\in C## such that ##x\sim y## holds that ##y\in C##.
All of these forms are easily seen to be equivalent, but sometimes one equivalent form might give more insight than another one.
Related to Understanding Saturated Sets in Quotient Maps
What is a quotient map?
A quotient map is a type of function in mathematics that maps one set onto another by identifying certain points in the first set as equivalent. The resulting quotient set is a partition of the original set, where each element in the partition represents a set of equivalent points in the original set.
How is a quotient map different from a regular map?
A quotient map differs from a regular map in that it does not have to be one-to-one or onto (surjective). Instead, the focus is on identifying equivalent points and creating a partition of the original set.
What are some applications of quotient maps?
Quotient maps are commonly used in topology, where they help to identify the structure of a topological space by mapping it onto a simpler space. They are also used in group theory, where they help to define quotient groups.
How do you determine if a map is a quotient map?
To determine if a map is a quotient map, you can use the following criteria: 1) the map must be onto (surjective), 2) the pre-image of an open set must be an open set, and 3) the pre-image of a closed set must be a closed set.
What is the relationship between a quotient map and its inverse image?
The inverse image of a quotient map can be used to define the equivalence relation on the original set. This means that the inverse image of a quotient map helps to identify which points in the original set are considered equivalent and will be mapped to the same element in the quotient set.
  • Topology and Analysis
