Design Tool for Compression Testing of Small Samples
A user is seeking design ideas for a tool to assist with compression testing of small samples (3mm x 2.4mm) on small platens (5mm x 5mm). Suggestions include creating a magnetic clip to hold the sample in place, using cyanoacrylate glue for positioning, or employing a thin sheet with a cut-out to secure the sample. Another idea involves supergluing the sample to a rod for easier clamping. The discussion emphasizes the need for effective alignment and positioning solutions for small-scale testing.
Andromeda1992
TL;DR Summary
I need to design a tool to appropriately position and align my compression samples
Hello all,
I am looking for some design ideas. I need to do some compression testing and here is my testing platens:
The platens are small (5mm*5 mm) and my samples are even smaller with the cross section of 3mm*2.4mm, so it would be difficult to both position them within the platens and align them with the center of the platens. I need to design a simple tool like a jig or something to help me position and align my samples. I can print that with a 3D printer. Does anyone have any design idea for such a tool. I'd really appreciate your ideas.
Welcome to PF.
What material(s) will your samples be made of? Ferrous or non-ferrous?
It looks like the right platen is stationary, so you could make a small magnetic clip that sits on the top surface of the right platen and holds the sample either magnetically or with a dab of adhesive. You can then position the clip left-right to put the sample against the right platen surface, and you can have some sort of up-down adjustment as part of the clip's sample holding mechanism.
Only half joking here. How complex are your requirements?
More ideas:
1) Stick the sample in place with cyanoacrylate glue.
2) Cut a (rectangular?) hole in a sheet of paper/plastic/rubber/thin sheet of something, press the sample into the hole, clamp the thin sheet in a larger fixture to position the sample.
3) Superglue the side of the sample to the end of a rod. Clamp the rod in an external fixture.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
