Vicke
- 8
- 0
Hello!
I have some plans that i want to share and get some feedback on before i start construction and buying parts. I have some land next to a lake that i can build a dam with head of 30m around 10000m2 and almost 50000m3.
I am thinking of solar panels and wind turbine to generate electricity to power pumps that fills the dam, then a 20kw generator driven by a pelton wheel is producing the electricity i will consume.
I'll use a computer to control the rpm of the generator by adjusting the jet flow to maintain 50hz, i will also have a diesel motor connected with one way bearings to the generator so i can start is and stop it while maintaining 50hz from the generator, i will also have a large flywheel on the same shaft with one way bearings and some clutch that make it start to spin slowly so i can power up the plant fast without waiting for the right rpm for too long.
My questions is how to make this most effective?
Im thinking of dc motors for the pumps, one per pump.
If i have max 600Vdc 30A from the solar panels i can have one 20kw dc pump directly connected to the panels at 50-100% power, and one 10kw ?V ?A at 25-50% power, and one 5kw ?V ?A for 0-25% power or even another smaller one. And the same setup for the wind turbine setup.
This setup at full consumption will use about 4m3 of water per minute maybe its possible to drive the generator directly from the pump motors via clutch or bearing when the usage and production is about the same to optimize efficiency.
I'm happy if anyone have some ideas on how to do this the best way and what motors, generators, panels, turbines and pumps i should use.
Thanks!
Thanks!
