Designing Bandreject filters
  • Thread starter Thread starter Corneo
    Designing Filters
A broadband reject filter can be designed by combining a lowpass filter with a cutoff frequency f_1 and a highpass filter with a cutoff frequency f_2 in parallel with a summing amplifier. Current designs may result in an unwanted peak at the center frequency, indicating that adjustments are necessary. Utilizing a higher-order equal ripple band stop filter design pattern could help achieve the desired broadband response. If this approach is ineffective, implementing ramp-up and ramp-down techniques may be required. Proper design considerations are crucial for achieving the intended filter characteristics.
Corneo
Is there a way I can design a broadband reject filter using a lowpass filter with cutoff frequency f_1 and a highpass filter with a cutoff frequency f_2,\ (f_1 \ll f_2) , combined in parallel with a summing amplifier? My current design yields a response that isn't a broadband, there is a significant bump at the center frequency. If I cannot do so, will I have to use a ramp up and a ramp down?
Sorry for having a run on sentence.
try higher order equial ripple band stop filter design pattern.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
