pmb
"Invariant Mass" vs "Proper Mass"
I see that there are many people here who prefer the idea that the mass of a particle is the magnitude of the the particle's 4-momentum.
However that is known as "Proper Mass" and some simply say "mass." However that idea is limited in use. It can't be applied in general.
Refer to this diagram in what follows --
http://www.geocities.com/physics_world/4-momentum.gif
When people measure things in Newtonian Mechanics one tends to measure them "simultaneously." E.g. It would be incorrectm, Newtonian Mechanics to measure the momentum of particle #1 at t = t_1 and then measure the momentum of particle #2 at t = t_2 and then add them - that wouldn't be a very meaningful quantity.
In the diagram --
C_1 is the world line of a particle #1 which has a non-constant velocity.
C_2 is the world line of a particle #2 which has a non-constant velocity.
The 4-momentum of each particle is well defined along its own world line. But when you try to add them - trouble! The magnitude of the sum of the two 4-momenta will be invariant. But not meaningful.
In reference to the diagram ---
Observer in frame S - This observer could add the 4-momenta of the two particles but he'll be tempted to use the values he measures at the "same time" as measured in his frame. In this case that corresponds to Events A and B.
Observer in frame S' - This observer could add the 4-momenta of the two particles but he'll be tempted to use the values he measures at the "same time" as measured in his frame. In this case that corresponds to Events A and C.
Each observer will measure 4-momenta and each will get a 4-vector with an invariant magnitude. However they will disagree on the magnitude.
The problem vanishes when all the particles move force free.
This problem does not exist with relativistic mass.
Pete
In the diagram --
Pete
