Detect current direction in water
7 replies · 1K views
hackhard
a bowl is filled with tap water .electric current is made to flow due to electrodes attached to rim of bowl(opposite sides of bowl)
i have 2 sense pins inserted into the water between the electrodes .
how can i convert this analog signal(vd across sense pins) to a digital signal to detect direction of current through water and use the signal in a logic circuit?
the 2 sense pins are fixed in water whereas polarity of supply electrodes is varying with time
electrode vd is max 5v min -5V. ammeter reads 700 microamps current flowing through water
how can i convert this analog signal(vd across sense pins) to a digital signal to detect direction of current through water ?
electrode vd is max 5v. ammeter reads 700 microamps current flowing through water
Are you doing this for some project? If budget is not a concern, you can try a hall effect current sensor.
yes all i need to know is if vd across sense pins is + or -ve
+ve or 0 vd = high output
-ve vd = low otput
-ve vd = low otput
Ok so you are interested in only the direction of the current? Not magnitude? Also, are you using a microcontroller?
no I am not
is there any alternative to adc?
I don't think so. Do the sensor pins detect current and give voltage as the output? It would be better if you posted a schematic.
will opamp voltage comparator do the job
Yes. But it won't be able to read the magnitude of the current. It will sense only the direction.
