Determine a basis for the image of F
  • Thread starter Thread starter victoranderson
    Basis Image
The discussion revolves around determining a basis for the image of a linear transformation F, specifically in the context of polynomial spaces P2(R) and P3(R). The original poster expresses confusion regarding the basis for the image after successfully finding the basis for the kernel of F.
  • Participants discuss the relationship between the kernel and image of the transformation, with some suggesting methods to find a basis for the image by identifying linearly independent vectors that span it. Questions arise about the dimensionality of the image and the nature of the vectors involved.
Some participants have confirmed the correctness of the kernel basis and are exploring the image basis. There is an ongoing examination of dimensionality, with clarifications about the dimensions of the spaces involved. The conversation reflects a productive exploration of concepts without reaching a definitive conclusion on the basis for the image.
There is a discussion about the dimensionality of the image of F, with references to the dimensions of the polynomial spaces involved. Participants are navigating the implications of the rank-nullity theorem and the definitions of the dimensions of vector spaces versus linear transformations.
victoranderson
Hello I have a question about part (b)
Now I know that F(f)(x) = [##\frac{1}{2}a+\frac{5}{6}b+\frac{17}{12}c]+[-a-2b-4c]x+[b+\frac{7}{2}c]x^{2}+[\frac{-2}{3}b-\frac{7}{3}c]x^{3}##
so Kernel of F : F(f)(x) =0
=> ##\frac{1}{2}a+\frac{5}{6}b+\frac{17}{12}c=0##
##-a-2b-4c=0##
##b+\frac{7}{2}c=0##
##\frac{-2}{3}b-\frac{7}{3}c=0##
which gives a=3c,b=-7c/2
so the basis for the kernel of F is (3,-7/2,1)
I think it is correct.
After that I am confusing about the basis for the image of F
When I convert the system of equations into matrix form and use wolframalpha to solve it
there are basis for column space and basis for row space
I do not know which one is the one I am looking for.
I think it should not be using matrix to determine the basis for the image of F because it should be used in the latter part.
The basis you found for the kernel of F is correct.
To find a basis for the image, you might start by finding a set of vectors that span the image of F and then find the largest subset that's linearly independent.
so the basis for the image is {##\frac{1}{2},\frac{5}{6},\frac{17}{12}##} and {##-1,-2,-4##}?
Another question.
Since F: P2(R) -> P3(R), the dim(F) is 3 or 4?
After doing this question I think dim(F) = 3, since dim(ker(F)) = 1 and dim(Im(F))=2
No. For one thing, the elements in the image of F are four-dimensional. Your vectors are three-dimensional.
Another question.
I don't know what you mean by "dim(F)".
vela said:
No. For one thing, the image of F is four-dimensional. Your vectors are three-dimensional.I don't know what you mean by "dim(F)".
That is my question.
How do we determine the basis for the image and the dimensions?
If you say the image of F is four-dimensional, then basis for the image of F can only be
span {(1/2,-1,0,0),(5/6,-2,1,-2/3),(17/12,-4,7/2,-7/3)} = span {(1/2,-1,0,0),(5/6,-2,1,-2/3)}
Is it correct now?Last time I thought dim(F) = dim(im(F))+ dim (ker(F))
Actually it is dim(P2(R)) = dim(im(F))+ dim (ker(F). I understand now.
Is it correct now?
Sorry, I misspoke earlier. The image of F isn't four-dimensional; it's a subspace of a four-dimensional space. My point was that the vectors in Im(F) should have four coordinates, not three, as you seemed to have inferred.
If you rewrite what you wrote earlier for F(f)(x) slightly, you get
F(f)(x) = a(1/2 + x) + b(5/6 - 2x + x2 - 2/3 x3) + c(17/12 - 4x + 7/2 x2 - 7/3 x3),
which you can interpret as a linear combination of three vectors. Hopefully, that's what you did to come up with the vectors above.
The vectors (1/2,-1,0,0) and (5/6,-2,1,-2/3) are linearly independent and span the image, so they are a basis for Im(F). There are two vectors, so the dimension of the image is 2.
Right. When you talk about dimensions, you're talking about the dimension of a vector space (or subspace). To ask what dim(F) is doesn't make sense because F is a mapping, not a vector space, and as you noted, the domain and codomain have different dimensions.
The relation dim(P2(R)) = dim(im(F))+ dim(ker(F)) reflects the fact that you can split the domain into two pieces. The vectors in one piece, ker(F), all map to 0. The vectors in the other piece map onto the image of F.
