Determine acceleration given work done and vertical distance
The discussion revolves around calculating acceleration when a 10 kg mass is raised 2 meters with 230 J of work done. The initial approach calculates force and acceleration using the equation W = Fh, leading to an acceleration of 11.5 m/s². However, participants highlight that this calculation does not account for gravitational force, suggesting that the lifting force must overcome both gravity and provide additional acceleration. By considering gravitational force, the total lifting force required is 215 N, resulting in a corrected acceleration of 21.5 m/s². The conversation emphasizes the importance of clarifying assumptions in physics problems to arrive at accurate solutions.
kaspis245
1. A body, whose mass is 10kg, is vertically raised upwards h=2 m . 230J work was done. Find the acceleration.
W = Fh
F = ma
W = Fh
F = A/h = 230J / 2m = 115J
F = ma
a = F/m = 115J/10kg = 11.5 m/s^2
The question is incomplete. The work done on what by what force?
If it is the work done by the lifting force on the mass, the acceleration of the mass is not only dependent on this force.
So, what's the solution then?
When a problem is (or even appears to be) incompletely specified, you should point that out, make some reasonable assumptions and state those assumptions along with your solution.
For instance you might assume that the work in question is that done by the external lifting force, excluding gravity.
You need to solve it with the information given, which means you need to make some assumptions.
It could be useful to turn around the problem and think about what would have been the work done if there were no acceleration. With that clear, it could be easier to see how to solve the original situation.
OK, I think now it's correct:
A = Fh
F = A/h = 230J/2m = 115N
F1 - mg = F
F1 = F + mg = 115N + 10kg*10m/s2 = 215 N
F1 = ma
a = F1/m = 215N / 10kg = 21.5 m/s2
Well, except that the lifting force and gravity are working in different directions ...
Hey, I have found another solution, but the answer is different:
A = Ek = mv2/2
V2 = 2A/m = 46 (m/s)2
V2 = vo2+2as
a = v2/ 2h = 11.5 m/s
So why is that?
That solution has the same problem as your original one. It assumes that there is no gravitation.
