Determine building height by viewing angles
To determine the height ratio between two buildings, the angles of elevation and depression from one building's roof are used. The angle of 21° above the horizontal to the top of the other building and 52° below to its base are critical for calculations. By establishing equations based on these angles and the height of the observer's building, the extra height of the taller building can be calculated. This allows for a comparison of heights to verify the friend's claim. Ultimately, the calculations will confirm whether the friend's assertion about the height difference is accurate.
lamamw
Warning! Formatting Template Missing.
You live in the building on the left in the drawing, and a friend lives in the other building. The two of you are having a discussion about the heights of the buildings, and your friend claims that his building is half again as tall as yours. To resolve the issue you climb to the roof of your building and estimate that your line of sight to the top edge of the other building makes an angle of 21° above the horizontal, while your line of sight to the base of the other building makes an angle of 52° below the horizontal.
I think you may have missed the rest of your question; in any case, it isn't clear what you're asking.
oh yeah
(a) Determine the ratio of the height of the taller building to the height of the shorter building.
(b) Determine whether your friend is right or wrong.
Do the drawing. Mark on it the height of your building.
Write an equation for the distance between the buildings in terms of the height of your building and an angle.
Write an equation for the extra height of his building in terms of the distance between them and another angle.
Solve the equations to give the extra height of his building in terms of the height of your building.
Answer the questions.
Job done.
