Determine Convergent or Divergent
6 replies · 2K views · last reply
e179285
an = [cos (3n) )] /n.cos(1/n) My solution is , I wrote an as
liman→∞ [cos (3n) )] /[ cos(1/n) / (1/n) ) .
We get liman→∞ cos(3n) / ( 1/0 ) .
I think solution of this limit is zero but ı'm not sure cos(3n) .I think cos(3n) as a number and number/infinity is zero .As a result of this ı say it is a convergent.
Is the correct approach to the question ?
You know that cos n ≤ 1 for any n, so cos(3n) ≤ 1 and cos(3n)/n ≤ 1/n
For the denominator I wouldn't write it as cos(1/n) / (1/n). Try thinking of 1/(n·cos(1/n)) as (1/n)·(1/cos(1/n))
What's the limit of 1/cos(1/n) as n→∞?
I don't think it is as simple as the OP indicates. Of course, for large n we can consider cos(1/n) to be essentially 1, so we almost have cos(3^n)/n --> 0. However, the sign changes due to cos(3^n) is very important; as n grows there is increasingly rapid oscillation in sign.
RGV
Use the squeeze theorem on [itex]\frac{\cos(3^n)}{n}[/itex], then evaluate [itex]\frac{1}{\cos(1/n)}[/itex]. Using the properties of limits: [itex]\lim (a.b)=\lim a . \lim b[/itex], you should get the answer.
No, it won't. The series sum 1/n diverges, but the series sum (-1)^n/n converges, so the sign changes are vital. In the current problem there are rapid sign changes (due to oscillation in cos(3^n)), but it is not clear whether the series alternates in any sense (that is, with any kind of nice pattern). I really do believe the problem is non-trivial.
RGV
RGV
But the problem involves sequence [itex]a_n[/itex] not series.
OK, then it's easy. I guess I thought the OP was doing what so many others have done, viz., saying sequence they mean series. I should just have taken him at his word.
RGV
