Determine Direct and Inverse Image f(E) and f^-1 (G)
  • Thread starter Thread starter phillyolly
    Image Inverse
The discussion revolves around the function f(x) = 1/x^2, defined for x in the real numbers excluding zero. Participants are tasked with determining the direct image f(E) for the set E defined as the interval [1, 2], and the inverse image f^(-1)(G) for the set G defined as the interval [1, 4].
  • Mixed
  • Some participants attempt to find the direct image f(E) and express confusion regarding the correct interpretation of the inverse image f^(-1)(G). Others suggest starting with the inverse function and checking its properties. There are discussions about the function's behavior and its monotonicity.
Participants are exploring various interpretations of the problem, with some providing insights into the function's properties and others questioning assumptions about the inverse function. There is no explicit consensus on the correct approach to finding the inverse image, and multiple perspectives are being considered.
There are indications of confusion regarding the definitions of direct and inverse images, as well as the implications of the function's behavior over specified intervals. Some participants note errors in previous assertions about the function's range and the nature of its inverse.
phillyolly
Let f(x):=1/x^2, x not equal 0, x belongs R
a) Determine the direct image f(E) where E:= (x belongs R : 1<=x<=2)
b) Determine the inverse image f^(-1)(G) where G:= (x belongs R : 1<=x<=4)
A) Let f: R -> R be defined by f(x):=1/x^2. Then, the direct image of the set E:=(x:1<=x<=2) is the set f(E)=(y:1<=x<=1/4).
If G:= (y : 1<=x<=4), then the inverse image of G is the set f^-1 (G)=(x:
And here I don't quite understand how to find an inverse image. Please help.
how about starting by finding the inverse map...
if you choose a reasonable domain f will be 1:1, so its inverse will exist such that f^(-1)(f(x)) = x
I have no idea what you are talking about, I am sorry...
What I have done:
f^(-1)(x)=x^2
This is the inverse formula. What should I do now?
I prefer to keep the variables different for the function & its inverse as below, i find it makes thing easier, so let:
[itex]y = f(x)[/itex] is a function that maps from x to y
for question a), if the domain of x is [1,2], then the y is in the range [1/4,1] as you've found
now for question b) assuming f is 1:1 we can find its inverse function, let's call it g
[itex]x = f^{-1}(y) = g(y)[/itex] which maps y back to x
now with all that in mind, starting with the function
[tex]y = f(x) = \frac{1}{x^2}[/tex]
you've said the inverse funtion is
[tex]x = g(y) = f^{-1}(y) = y^2[/tex]
lets check if it actually satisfies the inverse property
[tex]f^{-1}(f(x)) = g(f(x)) = (f(x))^2 = (\frac{1}{x^2})^2 = \frac{1}{x^4} \neq x[/tex]
so this is not infact the correct inverse function
to find the correct inverse, start with
[tex]y = \frac{1}{x^2}[/tex]
now solve for x in terms of y, that gives you g
I am so lost with your last comment. I can only see that this formula is the same as in your previous post.
Please any clues?
OK, I think I got it. Please check if I am right,
yep that looks good
[tex]y(x) = \frac{1}{x^2}[/tex]
so rearranging gives
[tex]x(y) = \sqrt{\frac{1}{y}}[/tex]
Everyone has been focusing on (B) but let me make an obvious point 1 is not "less than or equal to" 1/4! Also, it make no sense to say "y such that x has some property". What you should have is f(E)= {y: 1/4<= y<= 1}.
Hi! This is an old posting of mine. I am going back to this discussion. Is it right that for question b the answer is:
f^(-1)(G)={1/2<=x<=1}
? Thanks!
No, it's not. Notice that if x= -1/2, y= 1/(-1/2)^= 4. f is an even function so its graph is symmetric about the y-axis. lanedance made an error when he said the inverse function is given by [itex]x= 1/\sqrt{y}[/itex]. In fact, this function does not have an inverse!
In my first year in grad school, I had to present, before the class, a proof involving [itex]f^{-1}(A)[/itex] where A is a set. I did the whole problem assuming that f had an inverse- very embarassing!
The way you should have approached the problem is to look for x such that f(x)= 1/x^2= 1 and f(x)= 1/x^2= 4. The first equation has solutions 1 and -1, the second has solutions -1/2 and 1/2. Further, the derivative of f is -1/x^3 which is always negative between 1 and 2 and positive between -2 and -1. The fact that the function is decreasing on one interval and negative on the other tells you the domain is just the two intervals, [itex]1< x\le 2[/itex] and [itex]-2\le x< -1[/itex].
If, for some x in either of those intervals, the derivative were 0, you would have to consider the possibility that there is a turning point in the interval.
this isn't very fresh in my head, but I'm not sure I understand
Unless I'm missing something f(x):=1/x^2 on 1<=x<=4 is monotone decreasing with f'(x) not zero anywhere so the inverse exist
But it is not x, in the original function, that is between 1 and 4. The problem was to find [itex]f^{-1}(G)[/itex] where G is [1, 4]. If we write the original function [itex]y= 1/x^2[/itex]. Then we are looking for x such that [itex]1\le y\le x[/itex].
Yes, the problem was written in terms of [itex]f^{-1}(x)[/itex] with [itex]1\le x\le 4[/itex] but in terms of the original function, y= f(x), it is y that is between 1 and 4.
Is there a reason why LaTeX is not working?
The solution of f(E) is not right because 1≤ y≤ 1/4 would imply the set (-∞,1/4] U [1,∞). But, f(1.5) = 0.444 ∉ (-∞,1/4] U [1,∞) whereas 1.5 satisfies x ∈ [1,2]. Therefore f(E) is derived as follows:
f(E)= f{x∈ ℝ : 1≤ x ≤ 2}
Now, 1≤ x ≤ 2 ⇔ 1≥ 1/x ≥ 1/2 ⇔ 1≥ 1/x^2 ≥ 1/4 ⇔ 1≥ y ≥ 1/4
∴ f(E) = {y∈ ℝ : 1/4 ≤ y ≤ 1}
  • · Replies 20 ·
