Determine resonant frequency of an AC voltage source
The discussion revolves around determining the resonant frequency of a series RLC circuit using an AC voltage source, ammeter, and voltmeter. Participants explore experimental methods to identify the frequency at which current is maximized and the implications of voltage measurements across different components in the circuit.
  • Homework-related
  • One participant suggests measuring the effective current at various frequencies to find the maximum current, expressing uncertainty about the voltmeter's application.
  • Another participant proposes using the voltmeter across the capacitor or inductor, indicating it would show a maximum at resonance.
  • A counterpoint is raised regarding the behavior of the capacitor at DC and the inductor at high frequencies, questioning the validity of the previous suggestion.
  • There is a discussion about the voltage across the resistor in a resonant AC RLC circuit and whether it equals the source voltage.
  • One participant clarifies that at resonance, the voltages across the inductor and capacitor are large and 180° out of phase.
  • Another participant suggests using simulation software to visualize voltage changes across components versus frequency, emphasizing the importance of understanding impedance.
  • There is a conditional statement regarding the resonant frequency depending on the relationship between resistance and the square root of the inductance and capacitance, indicating that the best measurement location for the voltmeter may vary based on these conditions.
Participants express differing views on where to apply the voltmeter and the implications of voltage measurements across components. There is no consensus on the best approach or the behavior of voltages at resonance, indicating multiple competing views remain.
Participants discuss the behavior of circuit components under different frequency conditions, but there are unresolved assumptions regarding the specific values of resistance, inductance, and capacitance, as well as the implications of using an AC voltmeter.
AndrejN96
Given a series RLC circuit, with one R, one L, and one C element, and an AC voltage source with variable frequency, find the resonant frequency experimentally given an ammeter and a voltmeter.
The current in the circuit when the circuit is in resonance is maximum.
The imaginary part of the total impedance/admittance of the circuit is zero.
I would just measure the effective current using the ammeter for different frequencies and then note at which frequency is the maximum, but I am worried about the given voltmeter - any ideas on where to apply it?
Across the capacitor or the inductance. It will show a maximum at resonance.
That's not true! At DC the capacitor will behave like an open and ALL the voltage will be dropped there (no current!). At very high frequencies the inductor will look like an open and all the voltage will be dropped there (again no current).
So, what's the third choice? :smile:
The voltage of the resistor? And if yes, what with it?
EDIT: Will the voltage across the resistor in a resonant AC RLC circuit be equal to the voltage of the source?
I meant using an AC voltmeter, of course. At resonance, the voltages across the inductor and the capacitor will be very large and 180° out of phase.
An AC voltmeter is assumed given that the problem involves AC voltages.
AndrejN96: Voltages across individual components will vary with frequency and fairly smoothly. It would be worthwhile to pick a hypothetical set of component values and sketch the voltages across the components versus frequency (or "cheat" and get ahold of a simulation software to do it for you! LTSpice is excellent and free). A programmable calculator will do in a pinch to calculate and sketch voltage vs frequency. This assumes that you know how to work with impedance or at least reactance.
As you stated in your problem, you expect the current to be maximized at resonance. What does Ohm's law lead you to expect for the resistor voltage at resonance?
As Svein indicated, voltage phase is of interest. What do you know about the impedances of the L and C with frequency? Is there anything special about them at resonance?
If (1/R)√(L/C) >1 then you'd be right, the resonant frequency would be where the voltage across either L or C is greater than at any other frequency, from dc to infinity. But if R > √(L/C) this would not be true. So the best place for your voltmeter is the one hinted at in post 3.
  • · Replies 21 ·
  • · Replies 40 ·
  • · Replies 16 ·
