Determine the coefficient of kinetic friction
The discussion revolves around calculating the coefficient of kinetic friction for a 20.0g object released from a compressed spring on a tabletop. The object slides 1.25m before falling 1.60m to the floor, with the spring compressed by 10cm. Key equations include the potential energy of the spring and the work done against friction. Participants are encouraged to analyze the energy transformations and consider the effects of friction on the object's motion. The conversation emphasizes understanding the relationship between the spring's energy and the object's displacement.
woopycushion
A 20.0g object is placed against the free end of a spring (k = 25.0 N/m) that is compressed 10cm. Once released, the object slides 1.25m across the tabletop and eventually lands 1.60m from the edge of the table on the floor. Is there friction between the object and the tabletop? If there is, what is the coefficient of kinetic friction? The sliding distance on the tabletop includes the 10cm compression of the spring, and the tabletop is 1.00m above the floor level.
U(x)=(1/2)kx^2
F=-kx
W=fd
f=umg
F=umgd
d=(1.6-1.25) = .35m
U(x) = (1/2)(25)(.35^2)
Please explain your reasoning.
How are you thinking about the problem?
I can see some working - like you have d as the difference between the how far the object slides across the table and how far it flies off the end of the table ... and you appear to think this has something to do with the energy stored in the spring?
Consider:
How far was the spring compressed?
If there were no friction, and no air resistance, where would the object have ended up?
Is there friction in the system?
welcome to pf!
hi woopycushion! welcome to pf! :smile:
(try using the X2 button just above the Reply box :wink:)
show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
