Determine the electric flux through each of the sides
The discussion focuses on calculating the electric flux through the sides of a cube with a charge placed at its center. Initially, the user incorrectly calculates the flux using the wrong charge value and fails to account for the electric field due to the point charge. After clarification, they realize that the electric flux through a closed surface is equal to the charge inside divided by the permittivity of free space. The correct total flux is calculated as 2.37 x 10^5 N m^2/C for the entire surface, which should then be divided by six to find the flux through each side. The key takeaway is that the net electric flux through a closed surface simplifies the calculation significantly.
Rasine
A 2.10- mC charge is placed at the center of a cube of sides 6.40 cm. Determine the electric flux through each of the sides.
ok so electric flux=E(A)
so i figure that the electic flux will be the same for all six sides of the cube so i am just calculating the flux on one side then X6.
so that would be =(2.10x10^-6)(.064)(.064)=8.60x10^-9...for one side
and that would be 5.16x10^-8 N m^2/C for all 6 sides
but this isn't right...please tell me what i am doing wrong
So what is the charge? It looks like you wrote 2.10 mC, in the question, and then used 2.10x10^-6 C in the calculation.
You never actually calculated the electric field due to the point charge. The E in EA is electric field, in N/C. Check your units, they don't work out to the units of flux the way you have it.
ohh that's right...ok so now if i calcuate what E is
E=Kq/r^2
now r is at the the center of the cube so r=.064/2
E=(8.99x10^9)(2.1x10^-6)/.032^2=1.84x10^7
A=.064*.064=.004096
now 1/6flux=(1.84x10^7)(.004096)
flux=4.53x10^5...but that still isn't the right answer
help me please
\Phi=\oint{\bf E} \cdot{d}{\bf A}=\frac{q}{\epsilon_o}
Look closely at this. What does it say?
that means that the flux= the charge on the inside of the soild/ the constant e which is 8.85 x10^-12
Yes, so the net electric flux through any closed surface is equal to the net charge inside the surface divided by \epsilon_o.
How would you go about solving the problem knowing this? This makes it MUCH easier!
well the net charge inside is just 2.1x10^-6 C/e is that right?
That's right. As long as you're sure it's 2.10 \mu C, and not 2.10 mC.
right it is the first value...i don't have the notation for that in my keypad...
but the when i do that operation =2.37x10^5 N m^2/C which is wrong
OK, but that is for the flux through the entire surface.
I think you want the flux through one side, so divide by six.
