Determine the equation when given a graph
  • Thread starter Thread starter Feodalherren
    Graph
The discussion focuses on determining the equation of a sine function from its graph, specifically in the form y=Asin(Bx+C). The amplitude is identified as 2, while the period is calculated based on the graph's repeating intervals. Participants clarify that the period is derived from the formula 2π/B, and adjustments for phase shifts are discussed. The final equation proposed is y=2sin(π(x) - π/6), which incorporates both the amplitude and phase shift correctly. Overall, the conversation emphasizes understanding the relationships between amplitude, period, and phase shift in sine functions.
Feodalherren
The graph goes on for ever in both directions and we know that it's in the form
y=Asin(Bx+C)
I'm not sure what to do here. The amplitude is easy, it's 2.
C/B = Period
Correct?
I'm at a loss here.
y=Asin(Bx+C)
Or y = A sin(B(x + C/B))
C/B = Period
Correct?
No. If you had y = sin(x + D), the period would be ##2\pi##.
If you had y = sin(2(x + D)), the period would be ##2\pi/2##, right?
Feodalherren said:
I'm at a loss here.
Hmm I'm not sure I'm following your logic here. What throws me off is the fact that I have no pies on the X-axis. I have no idea how to start calculating the period.
If I had a 2pi it would be easy enough, I'd just see how many cycles the graph completes in a 2pi interval.
From your graph, can you estimate what the period is?
P=12/13
Feodalherren said:
P=12/13
How did you get that?
Your graph shows slightly more than one period of this function.
I graphed it by hand since I remembered it of my final today and I couldn't solve it. Assume that the graph goes on forever.
Hmm okay let me retry.
Every integer is divided into 6 parts as you can see from the graph.
When calculating the period I start from the 1/6 and go to 13/6 where the graph repeats itself.
This means that the period is 12/6 = 2?
The phase shift is 1/6 so the end result would be
y=2sin(2x-1/6)
Correct?
I feel like I'm missing a pi somewhere... Is it y=2sin(pi(x)-1/6) ?
Yes.
y=2sin(2x-1/6)
Correct?
No, but you're getting closer than you were before.
Let's look at a simpler example, y = sin(2x). Its period is ##2\pi/2 = \pi##. Your function has a period of 2, so the number that multiplies x needs to be what?
This is very close. If you want to shift the graph of y = sin(2x) to the right by 1/2, it would be y = sin(2(x - 1/2)). Does that give you an idea?
Hmm... Okay. My period is
2pi / 2 = pi.
y=2sin(pi(x))
Now, to phase shift 1/6 of a unit I do
y = 2sin(pi(x) - pi/6)
2pi / 2 = pi.
y=2sin(pi(x))
That looks right.
Thanks a bunch. Much appreciated. I totally bombed my final but at least I walked away with some new knowledge.
