Determine the Magnitude of the instantaneous Velocity
To determine the magnitude of instantaneous velocity at T=5s for the function x=AT^2 + B, where A=2.1 m/s² and B=2.8 m, one must understand the relationship between position and velocity, which is derived from calculus. Instantaneous velocity is found by taking the derivative of the position function with respect to time. The average velocity and displacement values provided indicate that the user is struggling with the fundamental concepts of calculus. It is suggested that the user review basic calculus principles to better grasp these concepts. Understanding these foundational ideas is crucial for solving similar problems in the future.
Chris Carney
Determine the Magnitude of the instantaneous velocity at T=5s
Function is x=AT^2 + B
A=2.1m/s^2
B=2.8 M
The previous questions answered on this problem are:
AVG Velocity is 16.8
Displacement is 33.6 from 3s to 5s
I'm not sure how to find either magnitude or instantaneous velocity. I need it broken down to the most basic steps to understand.
Do you understand what the relationship is between position and velocity? Have you taken calculus?
I took calc and calc 2 about 4 years ago, I passed with A's but left school on military orders and have just gotten back into school. I forgot a lot of what I learned then.
so, do you understand what the relationship is between position and velocity?
No, no I do not.
Chris Carney said:
No, no I do not.
Well, do you think maybe my repeatedly asking you about it is a hint to look it up?
I'm not trying to give you a hard time here, but part of what we do is try to help people learn how to get answers on their own, not spoon-feed answers. The relationship between position and velocity is extremely basic and one of the things that is generally brought up early in calculus so you really should study it a bit if you want to understand this kind of problem.
