Determine the muzzle velocity of a spring-launched projectiile.
  • Thread starter Thread starter howsockgothap
    Velocity
The discussion focuses on calculating the muzzle velocity of a spring-launched projectile, specifically a cork weighing 0.0046 kg. The spring constant is 10.8 N/m, and the spring is compressed to 0.11 m, with friction exerting a force of 0.25 N. The potential energy stored in the spring is 0.0653 J, while the work done by friction is -0.0275 J. The correct approach to find the cork's speed involves using the Work-Energy Theorem, leading to the equation KE = PE + Work done by friction. The initial calculation yielded a speed of 3.59 m/s, but the correct answer is 4.06 m/s, indicating a need to reassess the energy conversion approach.
howsockgothap
A gun that shoots a mass of 0.0046 kg uses a spring of constant 10.8 N/m. The 0.22 m spring is compressed to 0.11 m. The 0.22 m long barrel exerts a force of 0.25 N on the cork due to friction when it is fired. The spring obeys Hooke's law. The cork is projected horizontally.
The potential energy in the spring is 0.0653 J
The work done by friction on the cork is -0.0275 J
Question: What is the cork's speed in m/s at the muzzle of the gun? (Hint: Use the generalized Work-Energy Theorem)
W=deltaE=1/2m(v1-v2)2
I did the obvious and plugged in -0.0275=1/2mv22 since v1 is equal to zero. I ended up with an answer of 3.59 or so, but the study key our prof gave us says the answer is 4.06 m/s. Is there something wrong with my inital equation?
The conversion of energy is like this
Potential energy = work done against friction + KE
So you should have KE = PE + Work done by friction. (I changed against to by, so the sign changed)
Thank you, that helps very much.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
