Determine the period and frequency of SHM
To determine the period and frequency of simple harmonic motion (SHM) for a 1 lb weight suspended from a spring, the discussion focuses on setting up the correct differential equation. The static deflection is given as 24 inches, and the initial condition should be y(0) = 0, not y(24) = 1. The forces acting on the weight include the spring force, which is expressed as -ky, and the weight itself, leading to the net force equation. The resulting differential equation is my'' + ky = 0, where m is the mass of the weight and k is the spring constant. Solving this equation will yield the period and frequency of the SHM for the weight.
zaboda42
A 1 lb weight is suspended from a spring. Let y give the deflection (in inches) of the weight from its static deflection position, where “up” is the positive direction for y. If the static deflection is 24 in, find a differential equation for y. Solve your equation and determine the period and frequency of the simple harmonic motion of the weight if it is set in motion.
I'm having a hard time starting, I don't know how to set up the differential equation. I assume that an initial position will be y(24) = 1, but I can't get past the initial assumptions.
Anything to help?
Thanks!
I think you mean y(0)=24.
What are the forces on the weight when the deflection is y? What acceleration will result? How do you express the acceleration in terms of y and t?
I know that a potential differential equation may be my'' + ky = 0. Does this get me anywhere?
Any thoughts?
Let the modulus of the spring be k. When the deflection is y, what is the upward force exerted by the spring? (Be careful with signs.) What other forces act on the weight? What is the net force? How does that relate to the acceleration of y?
