Determining a sinusodial equation
  • Thread starter Thread starter Meeker
The discussion focuses on modeling the vertical position of a boat bobbing at a dock using a sinusoidal equation. The amplitude is determined to be 0.9 meters, and the value of k is calculated as π/2 based on the period of 4 seconds. To find the constants d and c, the mean position can be set at y=0, resulting in c=0, and if t=0 is chosen when the boat is at the mean position, then d=0 as well. The participants seek clarification on these calculations and how to apply them effectively. The thread emphasizes understanding the sinusoidal function parameters for accurate modeling.
Meeker
A boat is tied up at a dock and bobs up and down. The vertical distance between its high and low point is 1.8 m and the cycle is repeated every 4s.
a) Determine a sine equation to model the vertical position, in metres, of the boat versus the time, in seconds.
b) Use your model to determine when, during each cycle, the boat is 0.5 above its mean position. Round your answers to the nearest hundreth of a second.
y= a sin (k(x-d))+c
Period Length = 2 pi/k
a = amplitude
k = horizonatl stretch/compression
d= horizontal translation
c= vertical translation
Not sure If I am correct so far, but I found the amplitude and k value.
A=0.9 (Divided 1.8 by 2) and K = pi/2 ( I found that doing PL = 2pi/k)
Not sure how to get d or c though.
Would appreciate any help. Thanks
Excellent! As for "d" and "c", they depend on your choice of coordinate system: if you take y= 0 to be the mean position of the boat, the c= 0. If, also, you choose t= 0 to be when the boat is at that mean position, then d= 0.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
