Determining radius of electron's orbit Need help .
  • Thread starter Thread starter gookies
    Orbit Radius
To determine the radius of an electron's orbit in a positively charged helium atom, the angular momentum equation L = sqrt(k * e² * m * r₀) needs to be adjusted for the atom's two protons. The discussion emphasizes the importance of correctly identifying the charges involved, with q1 being the charge of the two protons and q2 being the charge of the single electron. Participants clarify that solving for velocity is not necessary; instead, they suggest substituting the angular momentum into the force equations to derive the radius. Ultimately, the correct approach involves ensuring accurate charge values and applying the modified equations. The final consensus is that plugging in the correct values will yield the correct radius.
gookies
A positively charged Helium atom has two protons in the nucleus and one electron in the shell, in a classic model of the atom, this electron is in a circular orbit around the nucleus with an angular momentum of 4.718x10^-34 Js. What is the radius of the orbit?
L = sqrt k*e2*m*ro
Using that equation, I've tried solving for the radius, but I'm not getting the correct answer. The professor told us it had to do with this equation, so I'm not sure what I'm doing wrong. I've gotten 2.37*10^-10m as my answer.
Hello gookies,
Welcome to Physics Forums!
gookies said:
L = sqrt k*e2*m*ro
Using the specified classic model, the above equation might apply to a neutral hydrogen atom, but not a positively charged helium atom.
Try to re-derive the equation for a positively charged helium atom. Note that,
F_e = k\frac{q_1 q_2}{r_0^2}
F_{centrepital} = \frac{mv^2}{r_0}
And if the velocity is perpendicular to the radius,
\vec L = \vec r_0 \times m \vec v \ \rightarrow \ L = r_0mv
Then substitute in the charges accordingly (remember the helium atom has two protons, not one). :wink:
Ah. I'm still confused. So do you have to solve for the velocity first and substitute F for mv^2/r? So the end equation would be, mv^2/r = k q1q2/r^2? And with the charges, would q1 be the charge of the electron and q2 would be the charge of 2 protons?
That's what I did anyway, yes. :approve:
After you solve for the velocity, modify it accordingly to make it into an expression for angular momentum.
Yes, that's right. :approve: Or you could make q1 be the charge of the two protons (in the nucleus) and q2 be the charge of the single electron. Just pick one to be the nucleus and the other to be the electron. Which one is which doesn't matter.
Okay, I just looked at it and you don't have to solve for velocity. I changed L=r*m*v to solve for v and substituted v in the equation of F = mv^2/r. I set that equal to kqq/r^2 and then I eventually set everything equal to L first, then solved for r. my final equation was, L^2 = k*q*q*r*m. Would that be correct, Collin?
Edit: Realized it's exactly like the equation I gave. :( Not sure what to do.
Yes, your way will work too. :approve:
It's almost the same. In the equation you derived there is a q1q2 instead of your original equation that had an e2. The important point here is that in a positive helium ion, q1q2 (remember, the nucleus of the helium ion has two protons, not one).
Plug in the charges and see what you get. :wink:
Ah, it works now. I guess it was just plugging in my numbers that screwed me. Thanks Collin!
