.Determining Reflected & Transmitted Waves
  • Thread starter Thread starter sweetvirgogirl
    Waves
To determine reflected and transmitted waves at a potential barrier, one must apply continuity conditions to the wave function and its derivative at the barrier's edge. The continuity equations are Yi(a) + Yr(a) = Yt(a) and Yi'(a) + Yr'(a) = Yt'(a), where Yi, Yr, and Yt represent the incident, reflected, and transmitted waves, respectively. The wave function must be continuous and differentiable everywhere, particularly at points of potential discontinuity. For specific cases, such as a beam of particles encountering a potential step, the wave function can be expressed as Y(x) = 1 e^(ikx), with amplitudes determined through these continuity conditions. Understanding these principles is crucial for accurately calculating the probabilities of reflection and transmission.
sweetvirgogirl
if you know the wave ...
how do you determine the reflected and transmitted waves?
the book tells you to enforce the required continuity conditions to obtain their (possibly complex) amplitudes
You cannot expect a coherent answer when you ask something this vague.
Zz.
As vague as that question is, I think the answer you are looking for is that:
Y= Psi because I don't know how the nifty regulars use that fancy font
Yi: Incident wave
Yr: Reflected wave
Yt: Transmitted wave
Y': Derivative of wave equations with respect to position (x)
Lets assume that the potential barrier is at x = a
you have two continuity equations
I doubt that answers your question since I am not sure what it is, but you can figure everything out from these continuity equations.
Yi: Incident wave
Yr: Reflected wave
Let me type the exact q ...
A beam of particles of energy E and incident upon a potential step of U0 = 3/4 E is described bby the wae funciton
Y(x) = 1 e^(ikx)
The amplitude of the wave (related to the number incident per unit distance) is arbitrarily chosen as unity.
a) Determine completely the reflected and transmitted waves by enforcing the required continuity conditions to obtain their (possibly comlex) amplitudes
b) Verify that the ratio of reflected probability desnity to the incident probability desnity agrees with
the equation ... T = ... R = ...
what i don't get is what the hell is "required continuity conditions"
The wavefunction and it's derivative must be continuous at the barrier's edge.
...which is a specific part of the requirement that the wavefunction be continuously derivable EVERYWHERE.
You can use https://www.physicsforums.com/misc/howtolatex.pdf" from where you can copy and paste individual characters.
wave function derivatives
Gokul, with step functions, delta-functions, and linear-cusp functions being commonplace portions of model potentials, that was a VERY misleading thing to say.
If the Potential is smooth, then the wave function will be also;
If the Potential has infinities, jumps, or kinks, then the wave function
will have discontinuous 1st, 2nd, or 3rd derivitives ...
otherwise the equation isn't satisfied.
