Determining spring's max compression on frictionless track
To determine the maximum compression of a spring on a frictionless track, a 0.280-kg block moving at 1.30 m/s collides with a spring of force constant 43.6 N/m. The calculations involve using energy conservation principles, equating gravitational potential energy to spring potential energy. The maximum compression is found to be approximately 0.11 meters. An alternate method for solving the problem is also presented. The solution effectively demonstrates the application of physics concepts to find the spring's maximum compression.
mandy9008
A 0.280-kg block along a horizontal track has a speed of 1.30 m/s immediately before colliding with a light spring of force constant 43.6 N/m located at the end of the track. What is the spring's maximum compression if the track is frictionless?
mgy=1/2mv2
y=1/2v2 / g
y=1/2 (1.30 m/s)2 / 9.8 m/s2
y=0.086m
mgy=1/2kx2
x2 = 2mgy / k
x2 = 2 (.280 kg)(9.8 m/s2)(0.086m) / 43.6N/m
x=0.11m
Answer looks good, an alternate method is shown in the attachment.
