Determining the brightness on a projected surface
Determining the brightness of a projected image involves several factors, including the projector's lumens, the throw ratio, and the ambient light conditions. The Canon Rialis projector outputs 4500 lumens, but this measurement requires conversion to radiometric units for accurate calculations. The projected illuminance can be estimated using geometry, considering the image size and distance from the surface. The reflectance properties of the projection surface also play a crucial role in how much light is scattered back to the viewer. Ultimately, using a light meter for direct measurement is recommended for the most accurate assessment.
Gbollag
I'm trying to determine how bright my projection image will be on a projected surface. I'm struggling to find a formula for this. I'm using (for example) the Canon Rialis projector which is 4500 lumens. I would be using the zoom lens with maximum zoom so the throw ratio would be 7:1. At a distance of 100 feet from the projected surface the projection would have a width of 14.28 feet. Also we are assuming the ambient light will be around.5 foot candles. (it will be after dark but outdoors in an urban environment). Any help is much appreciated.
Get an extension lead and test it out. The final figure would be a bit meaningless in comparison to seeing it with your own eyes.
Gbollag said:
I'm trying to determine how bright my projection image will be on a projected surface. <snip>
This type of question seems to pop up fairly regularly. The basic difficulty is that you don't have sufficient information to get a result.
Start with the projector: 4500 lumens. That is a photometric unit, not a radiometric unit. The radiometric equivalent is Watts, but your projector is not emitting 4500W of light- you need to know the spectral distribution of the light in order to convert it.
Then, you are collecting the light and projecting it onto a wall- so a better place to 'start' would be the projected illuminance (lux), which in radiometric units is W/m^2. Again, unless you know the optical properties of the projector lens, you can't easily figure this out. But you may be able to estimate it with simple geometry, since you know the size of the image. Then you know the lm/m^2 incident on the wall.
Now, the wall is scattering the light back to your eye- unless you know the reflectance properties of the wall, you can't estimate how much light is scattered toward you. You may wish to assume the wall is Lambertian, then the flux is scattered uniformly into a half-sphere. Then you can calculate the luminance of the wall (radiometrically, it's the radiance W/(m^2*sr)). Then, knowing how far away from the wall you are and how large the pupil of your eye is, you can calculate the flux of light entering your eye (lm). If your surface is not Lambertian, then you need to know the bi-directional reflectivity function (BDRF), which tells you how the reflectivity varies as a function of incident angle, reflection angle, and wavelength.
As you can guess, it's a lot easier to simply get a light meter and measure it.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
