Determining the Ionic Radii of group 2 metal chlorides?
The discussion focuses on determining the ionic radius of Fe2+ and Co2+ cations in anhydrous salts FeCl2 and CoCl2, specifically in the context of their coordination number of 6. The user references a database for ionic radii and expresses uncertainty about whether to use the high spin or low spin state ionic radius. The consensus is that for octahedral complexes, particularly with weak field ligands like chlorides, high spin states are expected due to minimal splitting in the crystal lattice. Therefore, the high spin ionic radius should be applied for both cations in this case.
Jefffff
I need the ionic radius of the cation in the following anhydrous salts:
FeCl2 and CoCl2
Looking at this database: http://www.knowledgedoor.com/2/elements_handbook/shannon-prewitt_effective_ionic_radius_part_2.html
Knowing that the coordination number of both Fe2+ and Co2+ cations is 6, I am unsure which ionic radius I should use as one pertains to a low spin and the other is a high spin state. My guess is that I would use the high spin state ionic radius for both of these cations because it is octahedral in geometry in the crystal lattice, but I'm not too sure.
Any help is appreciated!
Chemistry news on Phys.org
Octahedral geometry by itself doesn't tell you much. (Tetrahedral complexes, on the other hand, are almost always high-spin, because of the small field splitting). For octahedral species, you have to look at where the ligands fall in the spectrochemical series. In this case, chlorides are weak ligands, so the splitting will be fairly small, and you'd expect high-spin complexes.
Likes Jefffff
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
