Jikx
- 207
I just can't quite get my head around this one.. and i suspect that the question or my head may have an error!
Sounds a bit like dilution eh? The way i tried to work it out was
1) The 10ml sample contained 0.03 moles of salt (n=CV)
2) The water removes salt at 0.03 (concentration is 0.03M, in 1L of water) moles per water change
3) The required level of ammonium sulfate in the internal solution is 10^-5 moles
And I'm already ran into trouble... the external solution has already removed all the salt in the solution in one go! Somethign is wrong here... thanks for anyones help!
You have an enzyme sample of 3.0M with respect to the salt, ammonium sulphate. You are aware that in order to eliminate interference by this salt in both the assays of protein content and the enzyme activity, the concentration of ammonium ions must be less than 1mM.
To achieve this requirement, an enzyme solution (10ml) was dialysed against 1litre of distilled water at 4 degrees C.
After dialsis with stirring for 4 hours, the concentration in the external solution had reached 0.03mmole/ml.
How many changes of water would you need in order for the ammonium sulphate to be sufficiently low (>1mM) ?
