Why do diesel engines produce less power than gasoline engines?
Diesel engines produce less power than gasoline engines primarily due to their lower RPM limits, which restricts the time available for complete fuel combustion. Although diesel fuel contains more energy and diesel engines are generally more efficient, they are designed for economy rather than high-end performance. Gasoline engines can achieve higher speeds because they operate at higher RPMs, allowing for greater power output. Modern advancements in diesel technology, such as turbochargers and common rail injection, have improved their performance, but they still prioritize torque and efficiency over maximum speed. Overall, the design and operational characteristics of diesel engines lead to different performance profiles compared to gasoline engines.
kalamar20
Hello all;
I have been thinking about this for some time and searching through the internet for it but couldn't get a satisfactory answer for it, so i decided to ask this to you. Here is my question:
If diesel fuel has more energy in it than gasoline does and if diesel engines are more efficient than gasoline engines, why do diesel engines create less power? For example, a car with a 1.4 diesel engine cannot exceed 130 km/h on a straight road but a car with gasoline engine with the same properties (except it's a gasoline engine:) ) can go up to 150 km/h. As far as i know, obstacles to speed on a straight road is just the air friction and that means gasoline engines produce more power (P=F.V), don't they?
Im stuck here and I will appreciate any help from you, thank you for your interest.
Gasoline engines tend to run at higher RPMs than diesel engines. For running a car at high speed, an engine turning at high RPM is a necessary condition, assuming sufficient power is available to overcome drag.
As has been discussed in these forums before, due to the nature of diesel combustion, there is an upper limit to engine RPM beyond which there is insufficient time available for complete combustion of the diesel fuel to occur.
It's not that diesel engines create less power than gasoline engines, it can be viewed that they create the same power with less fuel. Most diesels are designed for economy of operation, not top end performance.
Likes 1 person
OK, i understand thank you very much.
Likes 1 person
kalamar20 said:
Hello all;
Not knowing many of the specifics of your example, I can't really give an explanation regarding it. I can say that, in general, diesel engines DO have more horsepower and torque than a gasoline engine with the same displacement. Drop-for-drop, diesel fuel has much greater potential energy than gasoline. In modern diesel engines, they are considerably efficient due to the use of turbo chargers and intercoolers.
Noteworthy: the vehicles you are using as your example very likely have a factory-set limit on the revolutions/minute that the engines can output... and/or the speeds you mentioned just happen to be the mechanical limit of the engine.
As high speed diesels have evolved their dynamic performance has approached that of gasoline engines.
Some very significant steps in the evolution so far have been indirect injection, turbo chargers and common rail electronic injection.
Diesels may have a compression ratio of 20:1 which requires heavier construction than a gasoline fuelled SI engine with a maximum compression ratio closer to 10:1.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
