Aeronautic Freek
- 121
- 7
Difference between centrifugal force vs reactive centrifugal force?
and practic example
and practic example
1)is co-rotating frame same name for rotating frame and non-inertial frame?A.T. said:
Co-rotating means rotating with the space station. All 3 bodies are at rest in that frame, so the forces on each of them must balance.Aeronautic Freek said:1)is co-rotating frame same name for rotating frame and non-inertial frame?
Because it's a frame invariant interaction force. It can be measured with a scale at the wall of the station, and that scale will read the same in every frame.Aeronautic Freek said:2)why in co-roating frame we have Frcf?
Dale said:In a co-rotating frame the rock is stationary. It is still acted on by the centripetal interaction force from the rope. In order to explain its motion in this frame we need to invoke an outward pointing inertial force called the inertial centrifugal force. This force does not result from any interaction, it does not have a 3rd law pair, it is not detected by the accelerometer, and it only exists in the rotating reference frame. That said, it is necessary for describing the motion of the rock in the rotating reference frame
A.T. said:Because it's a frame invariant interaction force. It can be measured with a scale at the wall of the station, and that scale will read the same in every frame.
So what is free body diagram for astronaut in co-roataing frame?A.T. said:There is no general relation between their magnitudes, even if they are equal in some cases. Also note that they act on different bodies.
in my logic Frcf and Ficf are same force and must be same in magnitude ...mass x Vsquare / radiusA.T. said:Frcf is not acting on the astronaut. The red forces act on the astronaut:
Fcp + Ficf = 0
We already have a 17 pages thread about that terminology:etotheipi said:...it just seems like a confusing terminology...
Aeronautic Freek said:forget about semantics,and just look at real life everywhere around you..
This entire issue is semantics. Nobody is disputing that it's possible to drive on a wall. The only question is about how to name the forces when you do so...Aeronautic Freek said:forget about semantics,and just look at real life everywhere around you..
CENTRIFUGAL FORCEIbix said:This entire issue is semantics. Nobody is disputing that it's possible to drive on a wall. The only question is about how to name the forces when you do so...
Aeronautic Freek said:CENTRIFUGAL FORCE
Yes, it is the third law reaction force to the centripetal force. So it is exerted by the rock on the rope in all frames.Aeronautic Freek said:Where is reactive centrifugal force in co-rotating frame in your discription, A.T. picture say that reactive centifugal force exist in every frame?
Your logic has some gaps:Aeronautic Freek said:in my logic Frcf and Ficf are same force and must be same in magnitude
show me equation for magnitude for Ficf and FrcfDale said:Your logic has some gaps:
1) they act on different objects
2) the reactive force exists in all frames
3) the inertial force exists only in rotating frames
4) the inertial force violates Newton’s 3rd law
The magnitude of Frcf depends on the rotation rate of the station.Aeronautic Freek said:show me equation for magnitude for Ficf and Frcf
so If we put weight scale between astronaut feet and station wall,scale will show Frcf and it will beA.T. said:The magnitude of Frcf depends on the rotation rate of the station.
The magnitude of Ficf depends on the rotation rate of the chosen reference frame.
Their magnitudes are not the same in general, just in some reference frames.
And as already said, they act on different objects.
It will show ##F_{\mathrm{rcf}}=F_{\mathrm{cp}}=m\omega_{\mathrm{station}}^2r=mv_{\mathrm{station}}^2/r##, yes. It will show this whatever frame you choose to use.Aeronautic Freek said:so If we put weight scale between astronaut feet and station wall,scale will show Frcf and it will be
mass x Vsquare / radius ?
(assumption that weight scale is massless)
If "V" is the tangential velocity of the astronaut in the inertial frame frame, then yes.Aeronautic Freek said:so If we put weight scale between astronaut feet and station wall,scale will show Frcf and it will be
