Difference between centrifugal force vs reactive centrifugal force?
78 replies · 8K views · last reply
Which outward force? In the inertial frame there's a centripetal force pointing towards the center caused by the tension of the string. Of course tension is a force binding the atoms/molecules together the string is made of. What else should it be? Maybe you are referring to the rigid-body approximation, where you substitute the (elastic) forces by the rigidity constraint?
The outward force of rock on string, as I said. That force exists at the interface between rock and string. It has a direction and a location. The direction is unambiguously away from the center of rotation.
Sure, but it's not a centrifugal force but just a force in an inertial frame. As you say, it's a "contact formce". So don't call something a centrifugal (inertial) force in an inertial frame. By definition there are no inertial forces in inertial frames of reference. The wrong wording leads to utmost confusion of the students, as is demonstrated by this thread which consists of 63 contributions just to eliminate the wrong thinking from this wrong wording again!
We do not seem to be communicating well.
You referred to string tension as centripetal. I took issue with this. String tension is neither centrifugal nor centripetal. It is a force pair, not a force.
There is a force pair that exists between rock and string. As you agree, it is a contact force. One member of that force pair is directed toward the center. One member of that force pair is directed away. I do not know of a pithy name other than "reactive centrifugal force" to refer to the outward force of rock on string.
Your words seem to suggest that you want to label the outward force of rock on string as "centripetal". But I am sure that is not what you intend.
It's in any case NOT a centrifugal force, because there is no centrifugal force in an inertial frame of reference by definition. In you example the force on the rock is due to the tension in the string. At the end of the string the rock's contact force is opposite and of equal magnitude of course (Newton's 3rd law).
It is a force that acts in the centrifugal direction. Taking "centrifugal" here to mean literally "away from the center".
I think perhaps the intention was that the terminology "centrifugal force" is so overwhelmingly associated with the ##-m\vec{\omega} \times (\vec{\omega} \times \vec{r})## that arises in a rotating frame of reference, that the term "reactive centrifugal force" (even though it's perhaps correct in the sense "fugal ##\equiv## away") is unhelpful for students. Not least because it presents the risk of conflating two very different ideas, just as these last few threads have demonstrated!
I fight against the use of the word "centrifugal" in the context of forces at all as long as we discuss physics from the point of view of an inertial observer, because it's much more economic to avoid misleading language and stick to clear definitions. A centrifugal force is an inertial force and as such can by definition only present in non-inertial (in this case rotating) frames of reference.
I don't think that anyone here disagrees with you. The term "reactive centrifugal force" is rather like "relativistic mass". It has a standard known definition that is not from Physics Forums and is not liked by most participants here, but sometimes you see someone who is confused by it and so we have to explain what it means and also why we dislike it.
vanhees71 said:
I fight against the use of the word "centrifugal" in the context of forces at all as long as we discuss physics from the point of view of an inertial observer, ...
I am even more annoyed by the "reactive" part because I dislike the "action/reaction" terminology with respect to Newtons 3rd Law.
Dale said:
So on PF out of the term "reactive centrifugal force" the only non-annoying part is "force" :smile:
It's a momentum flow, darn it :-)
Edit: And may the Schwartz be with you always.
  • Haha
jbriggs444 said:
It's a momentum transfer, darn it :-)
Haha! But Star Wars just wouldn't be the same if the Jedi had to say "Use the momentum transfer, Luke!"
I just watched Rogue One again, so I guess it would be "I am one with the momentum transfer, the momentum transfer is with me ..."
  • Love
I was allways excelent at math but allways strugle with physics and find very harder to understand than math..
I don't know if I am stupid or I have poor bascis of physics so it is hard to follow you ,but I find most of people consider physics harder to learn...
A.T. ,Dale,jbbriss44,Ibix etc,,are you proffesors of phyiscs or normal people,how you know physics so well?
Purely amateur here. I do IP networking for a living. Though the team members have nick-named me "The Professor".
I teach physics and programming professionally, but as an instructor in industry rather than at a university in academia
It's a spare time thing for me as well, although I have done postdoctoral work in physics in the past.
Frames, switching between them, and keeping track of how representations change as you do so is non-trivial, I think. This confusion of terminology about centrifugal forces doesn't help.
Are you a proponent of the Karlsruhe Physics Course? This is however the worst product of physics didactics ever. It's maximizing the confusion of students and is in some parts conceptually wrong (applying the Gauß integral theorem to non-closed surfaces, selling entropy as the same as heat or as a modern form of phlogiston etc. etc.).
Well, if you are excellent at math, try theoretical physics!
