Difference between in situ and potential temp in water
The discussion focuses on calculating the temperature change of a water parcel brought to the surface adiabatically, considering the compressibility of water. The user is attempting to derive an equation for the difference between potential temperature and in situ temperature, using the compressibility value provided. Key concepts include the relationship between energy change, temperature change, and work done during the adiabatic process, where no heat exchange occurs. Attention to units is emphasized as crucial for accurate calculations. The conversation highlights the need to integrate the work done in relation to volume change derived from compressibility to find the temperature change.
EMakepeace
Given the compressibility of water, how do I find the temp change of a water parcel brought to the surface adiabatically? I know that it is equivalent to work done by the parcel, but am stuck as how to move forward. Given a depth, is there an equation to work out the temp change?
compressibility=-1/V(dV/dp) and volumetric thermal expansion coefficient=1/V(dV/dT)
I tried to use the first equation to get vol change and then vol change for temp change, but my answers are far too high. I assumed a unit volume. For a depth of 5000m the difference should be around half a degree. I used a conversion of around 1 bar to 10m.
Hi EMakepeace, welcome to PF. What term are you evaluating? What state variable remains constant when a process occurs adiabatically and reversibly?
I am trying to derive an equation for the difference between potential temperature and in situ for a parcel of water. I realize that during the adiabatic process, there is no energy exchange between the parcel and the environment so that the change in thermal energy of the parcel equals just the work done as there is no heat exchange. I have only been given a value of compressibility (4.7x10^-5 bar^-1) and need to find the difference in temperature as the parcel expands with decreasing pressure/depth, as it is raised to the surface.
I'm sorry for rambling but this is my first post and am unsure to how all this works!
There are a couple different ways to tackle the problem. If you're given the compressibility value, it's probably a good idea to work from there. How would you express the energy change dE in terms of temperature change, and also in terms of work done? Does the fact that you know the relationship between dV and dP help you?
This is a problem where attention to units will make or break you. Track your units carefully.
I think I would relate dE to dT by dE=McdT, but this is where I am unsure. I can work out the change in volume from compressibility=-1/V(dV/dp), but then how to relate it to dE?
What is dE in terms of work?
dE=W(work done by the parcel)+Q(=0, in this case); so dE=W=PdV?
Great; try integrating this, knowing what you know about dV from the compressibility relation.
Many, many thanks!
