Difference of potential between 2 points
The discussion focuses on calculating the electric potential difference between two points, A and B, at distances d and 2d from a charge q, respectively. The potential difference is derived using the formula V_A - V_B = k (1/A - 1/B), where E is expressed as E = kq/r². There is clarification on the correct expression for the electric field, emphasizing that it should include the charge q. The participants confirm the need to multiply the final result by q to obtain the correct potential difference. The conversation highlights the importance of accurately applying formulas in electrostatics.
fluidistic
Point A is situated at a distance d from a charge q. Point B is situated at a distance 2d from the charge q, in the same straight line than the one of A and q.
Calculate the difference of potential V_A-V_b.
1.1 The attempt at a solution
V_a-V_B=k \int_ A^B E ds.
But E=\frac{F}{q}=\frac{k}{r^2} and ds=dr, hence V_a-V_B=k \int_ A ^B =-k \left [ \frac{1}{r} \right ]_A ^B =-k \left [ \frac{1}{B} - \frac{1}{A} \right ] = k \left ( \frac{1}{A} - \frac{1}{B} \right ).
Is that right?
I think that
<br /> F= \frac {kq_1 q_2} {r^2}<br />
so
<br /> E=\frac{F}{q} = \frac{kq}{r^2}<br />
not
<br /> \frac {k}{r^2}<br />
Right?
acr said:
I think that
so
not
Right?
You're right. So my result is the one I gave multiplied by q. I hope I'm right this time.
